ABS and Traction Control Light Intermittent.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MichaelSlover, Feb 9, 2021.
  1. Feb 9, 2021 at 8:57 AM
    MichaelSlover
    MichaelSlover [OP] Member
    Michael
    2009 Toyota Tacoma Access Cab 2.7L 4x4 Manual
    My 2009 Tacoma recently started to have the ABS and Traction Control light come on for a period of time then go away. I know its a sensor but first I believed my break pads needed to be serviced since I never had them done.
    Before I get raked over hot coals, anybody have this issue and know of easy solutions?
  2. Feb 9, 2021 at 9:01 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Pull codes. no easy solutions without realistic analysis. These lights are set to activate for a myriad of reasons and not necessarily involving what you see on the dash. Depending upon the model they are set to catch all, codes will be stored even if the light isn't active. Stop in an auto parts store and they can pull codes for you as well if you don't have a scanner. $30 on Amazon gets you a decent OBD-2 scanner to plug into any vehicle.
  3. Feb 9, 2021 at 9:27 AM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    200$ gets you a freaking awesome scanner, Best $ I have spent for messing with ABS
    TXpro4X4 likes this.
  4. Feb 9, 2021 at 12:19 PM
    MichaelSlover
    Michael
  5. Feb 9, 2021 at 12:35 PM
    Dacapster
    Hugh
    14 trd
    Many coming
    Launch scanners are pretty damn good, forever updated and thousands of different cars/trucks. pays for itself after helping a few peeps out )
  6. Feb 9, 2021 at 3:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    zippsub9 likes this.
  7. Feb 9, 2021 at 3:41 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    TnShooter[QUOTED] likes this.
  8. Feb 9, 2021 at 3:59 PM
    MichaelSlover
    Michael
    Yes it will go away for a while then come back on. Doesn't happen if I brake hard it is so random but consistent enough to annoy me. Last time I drove for 3 hours and it went away. Then it came back on when I wasn't even braking.
  9. Feb 9, 2021 at 4:38 PM
    TnShooter
    Deogee
    STOCK
    It may not show codes of the ABS light isn’t on.
    It’s well worth the money to buy a scam tool with the capabilities of ABS and SRS.
    Probably get by without SRS, but it’s nice to have if you need it.
