ABS and Traction control lights keep coming on
Discussion in 'Technical Chat' started by phreddyfoo, May 30, 2015.
  1. May 30, 2015 at 5:44 PM
    phreddyfoo
    phreddyfoo [OP] Well-Known Member
    Indiana
    I have a 2012 4wd TRD Dbl cab with 50k miles. The ABS and Traction control lights randomly turn on and off not while braking, just randomly. It has been to the dealer three times now and the computer is not registering the code or codes since the light has never been on at the dealer. They have cleaned the sensor each time and claim there was debris on it, but the lights keep showing up. What should I do?
    Thanks
  2. May 31, 2015 at 6:48 AM
    phreddyfoo
    Indiana
    So should I get a code reader to help diagnose the error? Or is it going to say ABS error or Traction Control error? That much is obvious.
  3. Jun 4, 2015 at 2:27 PM
    pos3idon
    pos3idon Active Member
    New York
    2011 Tacoma 4x4
    12 Volt outlet in bed, Leer Topper, UltraGauge, second battery
    Did you figure this out? I have the same issue (2011 Tacoma) going on but my truck is not producing any trouble codes (at least none that my Ultragauge can see).
  4. Jun 9, 2015 at 11:02 AM
    phreddyfoo
    Indiana
    Not yet, the lights still randomly come on and off. Dealer can't seem to figure out why.
  5. Jun 21, 2015 at 3:36 PM
    phreddyfoo
    Indiana
    When the dealer replaced my r/f wheel bearing, the seal wasn't installed correctly and it was slinging grease on the sensor. They replaced the bearing, seal and sensor, and all is right in the world.
