ABS and traction control lights on after Leveling kit install
Discussion in 'Suspension' started by Chipguy113, Apr 4, 2013.
  1. Apr 4, 2013 at 3:47 AM
    Chipguy113
    Chipguy113 [OP] New Member
    2012 sport
    ARB Front Bumper, leveling kit
    Does anyone know why my ABS light and Traction Control light would be on after putting a leveling kit on? Any help would be great. Thanks
  2. Apr 4, 2013 at 4:59 AM
    Mr. Derek
    Mr. Derek Member
    Minnesota
    '12 Tacoma TRD OR
  3. Apr 4, 2013 at 5:19 AM
    Large
    Large Red
    Mine has done this after every lift, and after every lift, either disconnecting the battery for 10 minutes, or an alignment will fix the issue.
  4. Apr 7, 2013 at 7:26 PM
    Chipguy113
    2012 sport
    I tried disconnecting the battery and the lights are still on. I will try an alignment next. Thanks for the help.
  5. Mar 7, 2022 at 5:57 AM
    comradeshrek
    comradeshrek Well-Known Member
    Artie
    2011 White Tacoma TRD Sport
    Did the alignment work? Toyota wants $149 to diagnose the lights. Im waiting for them to finish the alignment right now.
  6. Mar 7, 2022 at 3:21 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I assume you disconnected the spindle from the UCA and installed the shock from "above", as opposed to dropping the LCA away and installing from "below".
    If you were not careful when disconnecting the spindle from the UCA (allowed the spindle to swing away), you may have damaged the ABS wires or the plug. Inspect the ABS plug and wiring to see if there is obvious damage. I know @Ayeele had a similar issue when installing his King shocks. If memory serves me right, it was about $500 to fix the harness.
    Ayeele likes this.
  7. Mar 7, 2022 at 3:29 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    I damaged an abs cable doing a lift once. The cables were about $50 per side. It was an easy fix. I knew at the time I pulled one a little tight by forgetting to remove the bracket before dropping the spindle. Not much else that can go wrong there, that cable or the sensor itself, which was about $25 for after market.
    I dont see what an alignment would have to do with this unless the tech accidentally bumps whatever is actually wrong.
    Bertw192 likes this.
  8. Mar 7, 2022 at 4:39 PM
    Ayeele
    Ayeele Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    Yep. I paid 500 for that abs plug/harness, recalibration, and labor
  9. Mar 8, 2022 at 4:43 PM
    comradeshrek
    Artie
    We were careful with the wires. Even used bungies to hold the spindle assembly (callipers, rotors, hub, etc.) close to the car and not let it swing. Could still of course have damaged something. I I have an OBD reader that links to AutoDoctor and can't seem to wipe the code either.
    Bertw192[QUOTED] likes this.
  10. Mar 8, 2022 at 4:44 PM
    comradeshrek
    Artie
    Did you need to diagnos? If so, how did you know if it was cables or sensor?
  11. Mar 8, 2022 at 5:14 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    I replaced the sensors first as they were cheaper, then bought a cable and guessed the correct side as I knew I was a little rougher on that side. There is no calibration or anything its just a sensor and a cable. I think maybe you have to disconnect the battery or something after but that was it. I bought the oem toyota cable and the aftermarket sensors on Amazon iirc.
