ABS and Traction Control lights on.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rowlettr, Mar 17, 2015.
  1. Mar 17, 2015 at 7:21 AM
    rowlettr
    rowlettr [OP] New Member
    Roy
    NC/FL
    05 4Runner SUV
    I am new, so here goes:
    I have a 2005 4Runner. I had a problem and by looking through these threads I have corrected part of it.
    Everything was normal until I went to start it and all of a sudden the ABS and Traction (3 of them) lights were on. Also, I could not get the shifter out of park. I rotated the steering wheel, which has corrected this in the past, but the wheel moved freely and still could not get out of park. I had to force the shifter which caused a slight cracking noise. After that, it behaved normally, except the lights were still on.
    This is when I looked through this forum and found the suggestion to check fuses. I first checked to see if I had tail lights and I did not. I did find a 10A fuse in the engine compartment fuse panel that was blown. Replaced it and the shifter works normally now and I have brake lights. However, the ABS and traction lights are still on. I checked all other fuses that seemed related according to the owner's manual, but found no more blown.
    In the forum, there was discussion about blown or shorted ABS sensors. I am wondering if a sensor shorted and took out the 10A fuse with it. I have driven the car since, and the fuse remains good. Maybe a spike occurred when a sensor went out and that blew the fuse?
    I haven't educated myself about what ABS sensors are all about yet, so I thought I would ask for guidance from you experts.
    Thanks
  2. Mar 17, 2015 at 9:41 AM
    rowlettr
    Roy
    NC/FL
    05 4Runner SUV
    I looked, but there is only a little square cover, about 3/4" square. It pops off, but there is nothing under it but a plastic clip holder for that cover. I must not have that feature.
    Not an issue anyway now since the shifter works now.
  3. Mar 24, 2015 at 12:01 PM
    rowlettr
    Roy
    NC/FL
    05 4Runner SUV
    The next day after I replaced the blown 10A fuse, the ABS and traction lights went out on their own. I guess it reset itself. I noticed I had to reset my clock, so there was some interruption and reset that occurred.
    Thanks for all your help.
  4. Apr 1, 2015 at 10:11 PM
    saso05
    saso05 Member
    Rosendo
    Phoenix,AZ
    2009 Tacoma pre runner
    Flowmaster
    i have a 2009 Toyota Tacoma and these lights are on and my break lights are not working...Do you think it's the 10A Fuse?
    Thanks for your help!
  5. Apr 1, 2015 at 10:12 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is it blown ?
  6. Apr 1, 2015 at 10:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check it and see. There is a good possibility the answer is yes.
