ABS and VSC Off switch for Prerunner
Discussion in 'Technical Chat' started by Sterling_vH111, Mar 14, 2016.
  1. Mar 14, 2016 at 2:48 PM
    Sterling_vH111
    Sterling_vH111 [OP] Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    i have tried the abs switch mod explained in this thread, cut the light green wire under the drivers kick panel but nothing has happened. No lights, or driving effects.
    I really would like to put in a switch that disables VSC and ABS, I find the vsc especially annoying when Offroad.
    Has anyone done this successfully on a 2wd Prerunner?
    I've looked through many threads, but couldn't find another solution.
    Goals:
    No engine deactivation when sliding (vsc)
    No abs kicking in to ¨correct¨ vehicle when sliding (vsc)
    no abs when braking (abs)
  2. Mar 14, 2016 at 8:17 PM
    Jfunkysax
    Jfunkysax Well-Known Member
    Jay
    08 DCSBPR RED AS HELL
    Bilstein 5100's all around, Old man emu leaf springs, Volant cold air, body armor rear bumper with swing arm, Goodyear Wrangler Duratrack 255/70R18, Rockstar rims, EBC slotted rotors and green stuff brake pads, roll top bed cover.
    Did you ground it or cut it?
  3. Mar 15, 2016 at 10:06 AM
    Sterling_vH111
    Sterling
    socal
    I just cut it. Did not ground it.
  4. Mar 15, 2016 at 11:56 AM
    Sterling_vH111
    Sterling
    socal
    Should I try using a DPST switch and grounding to the engine bay area/neg batt. terminal? or is there a closer point I can ground from?
  5. Mar 15, 2016 at 7:03 PM
    Jfunkysax
    Jay
    You have to ground it ding dong. Do that at least. If u want add switch if you don't Wana see dash light. But cutting a wire never does anything. Your have to confuse the signal. Grounding it makes the ecu think it's on and disables the abs.
  6. Mar 16, 2016 at 3:38 PM
    Sterling_vH111
    Sterling
    socal
    OK thank you ha ha, I didn't realize that that was a requirement. And I don't think it said to do anything of that sort in Benson X's mod either. But not blaming him.
  7. Mar 16, 2016 at 8:56 PM
    Jfunkysax
    Jay
    Yea I wire tapped that line and just grounded it. Abs disabled. If ya want throw in a switch so ya don't have to stare at the lights on the dash.
    Did you use a 4x4 mod thread?
