abs/antiskid/traction lights on no codes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by falon871, Aug 19, 2018.
  1. Aug 19, 2018 at 11:15 AM
    falon871
    falon871 [OP] New Member
    2016 tacoma sr5
    My lights are on, no codes read. no check engine light. even when I disconnect the battery. and then reconnect, the lights are on as soon as the key is turned back on without even driving it. all sensors have been replaced. no change. no fuses blown. any ideas where to get troubleshooting info on this truck?
    thanks
  2. Aug 19, 2018 at 11:26 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Sounds like you should bring it to the dealer, see if there is something they can read that you can't pull with a standard obd ii code reader.
