ABS/BRAKE AND SPEEDOMETER NOT WORKING
Discussion in '2nd Gen. Tacomas (2005-2015)' started by James@50, May 4, 2020.
  1. May 4, 2020 at 5:02 PM
    James@50
    James@50 [OP] Member
    2006 Ext Cab Tacoma-2.7 Automatic
    Rims, Tires, Audio system
    I RECENTLY HAD MY TACOMA SERVICED AT THE DEALERSHIP FOR THIS PROBLEM. THE CODE SAID THE ABS ACTUATOR WAS BAD. I CHANGED IT OUT WITH A REFURBISHED ONE (AS A NEW ONE COST $1,400.00!) AND IT WAS FINE FOR ABOUT 20 MILES AND THE LIGHT CAME BACK ON AND THE SPEEDOMETER STOPPED WORKING. I CHANGED THE SPEED SENSOR ALSO. HAS ANYONE HAD THIS ISSUE AND CAN ADVISE ME OF WHAT MY NEXT MOVE SHOULD BE?
    THANKS GUYS
  2. May 4, 2020 at 7:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What exactly is the CEL Code?
    gasgasman likes this.
  3. May 5, 2020 at 7:23 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You will need a scanner that can read ABS codes. Mass Marketer auto parts stores might be able to read for free. Like jimmyh said, w/o a code, you don't know what's wrong.
  4. May 5, 2020 at 5:01 PM
    James@50
    Thanks guys for reaching out. I had a Toyota Tech scan the check engine light and his results said: Brake Actuator ASY/SKID ECU
  5. May 5, 2020 at 8:01 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You know that is the ECU on the ABS System right?
  6. May 5, 2020 at 11:53 PM
    James@50
    Thanks Jimmy...Is the ECU a separate part from the brake actuator or is it built into it?
  7. May 6, 2020 at 12:48 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    EdgemanVA likes this.
  8. May 6, 2020 at 4:14 PM
    James@50
    Thanks Jimmy, I watched the video and that is way above my pay grade!!!!
  9. May 7, 2020 at 2:09 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It really isn't hard at all and could save you a bunch of money if you can locate a junkyard part in working order.
    I wish you well.
  10. May 14, 2020 at 1:21 PM
    James@50
    I took my truck to a mechanic that had a scanner that Lester suggested and sure enough, it was the right wheel speed sensor! Thank you Jimmy and Lester, your info saved me a $1,400 dollar mistake at the dealership!!!!
    wilcam47 and CurtB like this.
  11. May 14, 2020 at 9:07 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    Glad you got it sorted and saved a bunch of money.
