ABS/Brake light on after tire blow out
Discussion in 'Technical Chat' started by Brandoaz, Jun 1, 2013.
  1. Jun 1, 2013 at 2:18 PM
    Brandoaz
    Brandoaz [OP] Member
    Hopefully ive found the correct area for this thread.
    Ive got an 07 Tacoma acess cab, the night before last i blew out the front left tire at about 60 MPH, came to a controlled stop about 200 yards later( i was on a transition ramp and had to get off of it).
    I had to have the truck towed as i didnt have the jack or tool to drop the spare with me( i just got this truck form brother in law and somehow he managed to leave these things elsewhere).
    So, after i got it home, i was able to drop and install the spare.
    I noticed the next time i drove it that the yellow ABS light and the red BRAKE lights are both illuminated.
    Brake fluid reservoir is at max line.
    I read somewhere that i can jump certain pins in the OBDII to get codes, but want to make certain i get the correct directions.
    Any other thoughts on what to check or what may be the issue?
    Thanks !
  2. Jun 1, 2013 at 2:32 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Check to see that the wires for the ABS system are secure at the affected wheel.
  3. Jun 1, 2013 at 4:27 PM
    Brandoaz
    Thanks for the reply, i have to admit im not familiar with the ABS wires and location, something i need to pull the wheel to do?
    I wondered about this, something that perhaps a flat tire could disconnect or dislodge?
  4. Jun 1, 2013 at 5:31 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    The wire is attached to the UCA just follow it down from there. Taking the wheel off would be easier.
  5. Jun 4, 2013 at 10:04 AM
    Brandoaz
  6. Jun 4, 2013 at 12:41 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    You could try, I haven't before. You could try just unpluging your battery to see if that will reset the code.
    That is the ABS senor wire.
  7. Jun 4, 2013 at 12:47 PM
    Brandoaz
    I did unplug battery for about an hour when this first started, didnt change anything.
    that wire doesn't look damaged at all, im going to check the other 3 wheels as well.
    My neighbor was just out and asked if i had actually tested to see if the ABS worked, so at 30 MPH i stomped on the brakes, it locked up. Ill check and see if it flashes me codes and post back.
  8. Jun 4, 2013 at 12:56 PM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Yes, that's it. They are extremely sensitive, some people have stretched them while doing brake jobs and they throw codes.
    Absolutely check the codes if you are competent enough to do so. Then you can be informed and go from there.
  9. Jun 4, 2013 at 1:07 PM
    Brandoaz
    jumping the OBDII resulted in the ABS light flashing
    34
    then
    41
    Going to post in that other thread to ask specifics about the chart they have. If anyone here has anything else to offer id like to hear it.
  10. Jun 4, 2013 at 3:23 PM
    Sandman614
    Sandman614 LRGRNR
    '06 SR5 Off Road
    41 is probably because you unhooked the battery.
    34,check that wheel sensor. Maybe some debris hit the wire or sensor.
  11. Jun 4, 2013 at 3:38 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
  12. Jun 4, 2013 at 3:55 PM
    Brandoaz
    Thanks for the replies
    Sandman514:
    I looked and nothing seems to be damaged( i checked all four), and the left rear specifically, again after seeing the code.
    Taco TX i dont see anywhere in that link how to clear the codes.
    So the 41 code is telling me it knows i unhooked the battery? will that clear on its own?
    So i can just unbolt the sensor and pull it out of where its bolted?
  13. Jun 4, 2013 at 4:04 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Yes and on the end of the sensor is a nipple which is a magnet. Check for debris being stuck to it. I believe it was step on brake pedal 8 times when you first flip key over, not hard just enough to flash the light. Research it a bit, i dont remember which site i found it on.
  14. Jun 5, 2013 at 2:14 AM
    Brandoaz
    ok, is there a trick to detaching the wiring clip from the sensor, or do i take the sensor out while attached to the wiring?
  15. Jun 5, 2013 at 2:20 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    You just need to lift up on the clip with a small tool like a pick or screw driver. Then undo the 10mm stud/nut on the abs sensor, pull it out and wipe it off with a clean rag, then re-assemble.
  16. Jun 27, 2013 at 6:49 PM
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    I'm troubleshooting the same problem that was caused by my atrac hack mod + off roading. I cut out a tiny square of rubber from each of my wheel sensor wires, turned the truck on and tested the white wire for power. I found out my left rear sensor is bad. To double check, I jumped the obd2 jack and got ABS/34 and VSC/43 which is left rear wheel speed sensor malfunction and decelerator sensor malfunction. I think the decel is fine tho.
