ABS/ Brake light???
Discussion in 'Technical Chat' started by Midnighttaco08, Aug 12, 2015.
  1. Aug 12, 2015 at 10:27 PM
    Midnighttaco08
    Midnighttaco08 [OP] Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Hi all, just drove home from dinner and on the way home, the abs light and brake light came on. I turned off the truck and they both turned off and did not come back on the entire way home?
    Anything to be worried about? Can I retrieve the codes it threw even thought the lights are not on?
    2008 TRD Off road with camburg UCA's and CO's and rear Dakars with 1 overload removed. Have had the front for over 3 year and Dakars for about 8 months. So I don't think it has anything to do with the lift because it's been so long with no problems.
  2. Aug 12, 2015 at 10:45 PM
    bcp280z
    bcp280z Member
    Ben
    Almost stock, speedway blue, access cab, wanna be 4wd prerunner 6 spd
    May be your master cyl, check brake/clutch reservoir and driver side floor mat. Mines been leaking for over a year, praying it wont go out. It's a pita to fix.
  3. Aug 12, 2015 at 10:53 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Check and make sure your bulbs aren't out (brake lights)
    These trucks abs light will turn on if the bulbs are out
  4. Aug 12, 2015 at 10:59 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    Just checked brake lights and all 3 work. Just check master cyl and all 4 wheel sensors for possible damage and everything looks spotless. No leaks on mast cyl. No leak inside under dash at pedal. Sensors look fine. And fluid is just under max...
    Any other suggestions? The lights also are both currently off. They haven't turned back in since the I restarted after they came on.
  5. Aug 12, 2015 at 11:14 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    Any brake master mechanics out there! Lol
  6. Aug 12, 2015 at 11:18 PM
    andrewribicki1
    andrewribicki1 Well-Known Member
    Andrew
    2013 TX Baja
    I posted in other to link to this thread so we don't have to check both :thumbsup:
  7. Aug 12, 2015 at 11:20 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
