ABS/Brake lights on. Needs new Actuator Assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Apr 18, 2020.
  1. Apr 18, 2020 at 1:50 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    So those lights have been on since march 2018 when I purchased it and have been driving it since relatively problem free .
    Had to make a panic stop once and found out that yep, definitely all manual brakes now.
    After replacing the speed sensors and wiring harness to no avail I decided to take it to my local Toyota dealership yesterday for diagnostics.
    2 hours later he comes back with a quote of $1,497.20 for part #44050-04080 Actuator assembly,labor included but said he couldn't guarantee it wouldn't fry it again as they couldn't find anything wrong with the wiring in those 2 hours.
    I thanked them for there time and was on my merry way to Ebay.
    Found the part (used with 30 day warranty) for $70 shipped.
    Has anyone replaced this before?
    I've never done anything with brake systems before but am willing to give it a shot to save $1400.
    Thanks TW.
  2. Apr 18, 2020 at 5:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m not sure, but you may need a bidirectional scan tool to purge the air from the ABS System.
    Maybe @Bishop84 or @Muddinfun will know?
    Jacked Burton[OP] and Jimmyh like this.
  3. Apr 18, 2020 at 5:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes a scan tool will be required to cycle the solenoids in a timed controlled manner.
    NOTE: using a jumper will burn up the solenoid coils.
  4. Apr 18, 2020 at 5:13 PM
    TnShooter
    Deogee
    STOCK
    Thanks Jimmy. :thumbsup:
    Jimmyh[QUOTED] likes this.
  5. Apr 18, 2020 at 6:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, it requires a scantool functional bleed. It's big money but I would just pay them to do it and the liability is on them.
    Jimmyh and Jacked Burton[OP] like this.
  6. Apr 18, 2020 at 6:46 PM
    Jacked Burton
    Couldn't I just attempt this with a bootleg copy of techstream?
    What's the worst that could happen if I'm already ABSless
  7. Apr 18, 2020 at 6:47 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    yup, about $35 on Amazon and a little wait to get the registration keys, about 48 hours.
  8. Apr 18, 2020 at 6:48 PM
    Bishop84
    You could, a soft pedal is the worst case scenario.
    It's not too hard with a techstream, just takes 2 people and patience.
  9. Apr 18, 2020 at 6:54 PM
    Jacked Burton
    This might be a stupid question but what would make changing this part out any worse than this on a 2007-2009 camry?
    There is no need if you are using a used (preprogramed) module or am I way off?
    https://www.youtube.com/watch?v=pPife7OD9LY
  10. Apr 18, 2020 at 6:57 PM
    Bishop84
    It's plug and play. Biggest thing is not stripping the thread on install. I'd say its a 5/10 on the DIY scale.
  11. Apr 19, 2020 at 7:51 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is what I did to get techstream..... Works just fine.
