ABS/Brake lights:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stewillard, Aug 25, 2020.
  1. Aug 25, 2020 at 12:45 PM
    Stewillard
    Stewillard [OP] Member
    Bill
    Oklahoma
    2007 4 cylinder
    Hello, I’m new here although I believe I was registered 10 or so years ago. Life circumstances sometimes change our priorities without warning. Regardless, I still have my Tacoma and I’m hoping for some help resolving an apparent ABS problem.
    The abs/brake lights are lit on my 2007 Tacoma yet my obd2 scanner gives me no related information. This was surprising to me, is it normal for it to show no abs info.?
  2. Aug 25, 2020 at 12:49 PM
    Muddinfun
    Muddinfun Well-Known Member
    Check for codes and go from there.
    First, connect terminal 4 and 13 of the OBD-II socket (under the dash in front of your left knee) with a jumper wire. (Those are the 4th from the left on the top and the fifth from the left on the bottom.)
    Turn the ignition to on. You'll notice lots of flashing lights, but just pay attention to the ABS light. Normally, it should be rapidly and steadily flashing, twice per second. If it has stored a trouble code, it will instead be flashing a pattern that will coding a two-digit number. There may be more than one code being flashed out. It will just repeat the code over and over, so you have plenty of time to figure it out and write it (them) down.
    NOW you can clear the codes. Just tap the brakes rapidly 8 or more times, about two taps per second. You don't have to jam on the brakes, just tap them enough to blink the brake lights. If you're successful, the ABS light should return to its normal fast blinking. Now remove the jumper wire, and finally turn off the key.
    Now when you turn on the key, the ABS light should just do its normal light for three seconds and go off. If it comes back on, you still have a problem
    Jimmyh and whatstcp like this.
  3. Aug 25, 2020 at 12:54 PM
    Stewillard
    Bill
    Oklahoma
    2007 4 cylinder
    Thank you, I’ll try the ASAP.
    Muddinfun[QUOTED] likes this.
  4. Aug 25, 2020 at 1:27 PM
    Stewillard
    Bill
    Oklahoma
    2007 4 cylinder
    Looking at the connector description I see that pin 4 is chassis ground and pin #13 isn’t connected on my model.
  5. Aug 25, 2020 at 1:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Aug 25, 2020 at 2:29 PM
    Stewillard
    Bill
    Oklahoma
    2007 4 cylinder
    Very good. I must have been looking backwards at the wiring diagram. The code seems to be 3,4. That is: 3 - 4 ——3 - 4 ——
    Does this mean a malfunction of the left rear wheel speed indicator?
  7. Aug 25, 2020 at 2:30 PM
    TnShooter
    Deogee
    STOCK
    That would indicate a Left Rear Wheel Speed Sensor.
    Muddinfun likes this.
  8. Aug 25, 2020 at 5:54 PM
    Stewillard
    Bill
    Oklahoma
    2007 4 cylinder
    Thank you all.
    TnShooter likes this.
  9. Aug 25, 2020 at 7:07 PM
    Muddinfun
    It could be the wires to the sensor. Have you been 4 wheeling in the brush lately? Or had it towed on a flatbed lately?
  10. Aug 25, 2020 at 9:12 PM
    Stewillard
    Bill
    Oklahoma
    2007 4 cylinder
    No for both questions but I’ll carefully check for wiring problems. Thank you for the advice.
  11. Aug 25, 2020 at 9:18 PM
    Muddinfun
    I think you can unclip the rear wire harnesses and swap them side to side as a test. Hook the right harness to the left sensor and vice versa. Obviously the ABS won’t work right if you slam on the brakes, but if you do the swap, clear the code, drive it a bit and then check the codes, if the code switches sides, you know it’s the harness and not the sensor.
    Jimmyh and TnShooter like this.
