ABS/Brake system warning/malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Florizona, Jul 17, 2024.
  1. Jul 17, 2024 at 11:59 AM
    Florizona
    Florizona [OP] Member
    Bryan
    2016 trd offroad
    Driving to work this am, doing approx 60mph on a significantly washboarded gravel road I got the "Check Brake System/ ABS" screens.. shortly down the road it went away momentarily, but then returned and has remained since... I assumed it was the a wheel speed sensor, but all 4 are registering in OBD fusion simultaneously and same speed..now I have no idea what to check or where..
    Replaced front pads a month ago due to grinding sound that I assumed was due to low pads, didn't go away, seemed to be coming from the rear, truck has 205k miles so figured it was probably time for shoes/drum service in the rear, sound went away yesterday..
    Any ideas? Thank you in advance.
  2. Jul 17, 2024 at 12:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don’t know about your ABS problem, but I can tell you that there is a simple inspection procedure for brake pads that mostly consists of measuring their thickness. I would not rely on noises or miles driven.
  3. Jul 17, 2024 at 12:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    First step is seeing what code(s) the ABS module has in it.
  4. Jul 17, 2024 at 12:49 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Is the check engine light on as well?
    Chew likes this.
  5. Jul 17, 2024 at 1:39 PM
    Florizona
    Bryan
    2016 trd offroad
    So i just got an alarm, lost most brake pressue and coasted into a loves truck stop (lucky)
    Right rear drum is leaking brake fluid and has apparently beel slinging it around for a little bit. Resivoir is pretty much empty.
    Can I refill and limp home or am I fucked and need a tow?
  6. Jul 17, 2024 at 4:09 PM
    ODtheOG
    ODtheOG Well-Known Member
    Mo
    Orange County
    2022 Tacoma TRD OR
    Need to scan the vehicle with a legitimate OBD reader
  7. Jul 17, 2024 at 4:59 PM
    Florizona
    Bryan
    2016 trd offroad
    Filled the reservoir, limped 35mi home, pulled into garage and lost all brake pressure again. Got super lucky. Reservoir completely empty again.. time to research the mechanics of drum brakes I suppose.
    BTW, No check engine light, not throwing any codes, all 4 wheel speed sensors functioning and communicating nominally. Absolutely leaking out the RR drum assembly.
  8. Jul 17, 2024 at 5:05 PM
    gudujarlson
    Minnesota
    If you are leaking brake fluid I don't think learning the mechanics of drum brakes is going to help you. You should instead inspect your brake hydraulic system: hydraulic lines, cylinders, and reservoirs. Your problem is likely going to be obvious after inspection.
    I will also say that if you aren't an experienced amateur mechanic, I wouldn't mess with a safety sensitive system like brakes. I'd take it to someone more experienced.
    Chew and RIX TUX like this.
  9. Jul 17, 2024 at 5:14 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    sounds like rear brake cylinder is bad/leaking.....shoes will be ruined.....prob due to year of truck would be better to get 2 new cylinders instead of rebuilding them, new shoes, spray everything with brake kleen.....or have a shop repair it if you have never done it
  10. Jul 17, 2024 at 5:30 PM
    Rusty66
    Rhode Island
    Glad you got it home! I’m interested in what actually failed I have not seen a wheel cylinder blow out in a long time.
    As for fixing it…..You’re going to need a lot of brake fluid. If the master went dry it needs to be bled first, then the rest of the system, lastly the ABS needs to be bled with a scan tool.
    Plan on a set of shoes, wheel cylinders and a new hardware kit.
    If you’re not a seasoned technician I suggest you take one side apart at a time, leaving the other as reference.
  11. Jul 17, 2024 at 7:02 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    There has to be a code. OR's are brake by wire in the rear so likely it knew it wasn't able to build rear pressure. You'll need to get the whole system bled including the abs system after you repair the leak.
  12. Jul 18, 2024 at 12:25 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Like already stated its likely the rear wheel cylinder, replace both sides, new drums, shoes and springs if they were not already done. Inspecting the wheel cylinders for any leaks by pulling back the boot should be part of the rear service, or its generally a better idea to always just replace the cylinders as part of the rear brake service anyway bc you are already in there with everything cleared away and the rear brakes can be bled pretty quickly.
    Florizona[OP] likes this.
  13. Jul 18, 2024 at 9:28 PM
    Florizona
    Bryan
    2016 trd offroad
    Did some research last night, made a parts list, ordered, paid for and picked up on the way home from work.. Hit the drums w some pb blaster then bolted them apart m8x1.25.. it was comical, buncha parts fell out. Old springs and pins and retainers. Shoes had approximately 0.0mm friction material remaining, I think I've found the source of the grinding sound lol..
    Heaps of grease and dirt and FOD in all the crevices. The rubber gaskets? Boots? endpieces? of the wheel cylinder (why is it called that, its neither cylindrical nor wheely, more of a hydraulic actuator but IDK) were compromised and pissing fluid when depressed, so theres the source of the fluid leak.
    Removed the wheel cylinder, and the drum components, cleaned all the gunk off all the parts, and called it for the day, 109F in the west facing garage at 1730 and my laptop just wasnt having it. Reassembly tomorrow. Yay.
  14. Jul 19, 2024 at 9:21 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Hopefully this gets you going soon!
    And as far as the rear brakes? Another 205k miles!
  15. Jul 19, 2024 at 7:31 PM
    Florizona
    Bryan
    2016 trd offroad
    made some progress today after work, got the other (non-exploded) side apart, WAY easier lol. There was actually friction material remaining on the shoes and everything wasnt covered in grease. So naturally I accidentally over-torqued and sheared off one of the 10mm mounting bolts for the wheel cylinder. Rookie shit. Additionally I realized that this component: the " parking brake shoe strut adjustment bolt" from the passenger (exploded) side is significantly bent.
    Any recommendations on sourcing this part? I dont see a number on the diagram. Apologies if this is a dumb question, Im new to this.. researching concurrently but wanted to ask the hive mind. Good times..
  16. Jul 19, 2024 at 10:50 PM
    Florizona
    Bryan
    2016 trd offroad
    Nevermind, figured it out. The bolt is 90080-1114 and the strut assembly is 04943-04010
  17. Jul 27, 2024 at 10:39 PM
    Florizona
    Bryan
    2016 trd offroad
    Sourced components from toyotapartsdeal.com Fast enough and factory oem. The strut set came with both sides and the springs.
    Put it all together, bled her out with assistance from a friend and his Autel device.
    Not nearly as hard as I thought it would be, biggest PITA was connecting the large springs on the parking brake strut assembly with my subpar pliers.
    Links that helped:
    Team OilDrop, straight to the point, no fluff. Excellent
    https://youtu.be/-dmUF5hbQEQ?si=LMZaoxizXoCcgfD4
    CarCareNut, voice is challenging sometimes but seems to know his stuff.
    https://youtu.be/qGeTOBWg3YE?si=JvNaM50FtVhft_eQ
    Faye Hadley, long but very detailed
    https://youtu.be/O-yN4LFlC6g?si=h_ze5S3AwwWuW73B
