ABS BRAKE TRAC OFF traction check engine light/ no speedo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewnali, Mar 14, 2023.
  1. Mar 14, 2023 at 10:50 AM
    drewnali
    drewnali [OP] Well-Known Member
    Drew
    Florida
    2013 4X4 SSM TRD OR DCSB
    Just had a slew of work done- including suspension, rear wheel bearings, re-gear, etc.
    Traction light was on when picking up- wasn’t too concerned, as I need alignment. As I drove home, I look down, and ABS BRAKE light is on, and speedo is at zero. Ummmm… bummer. Any ideas?
    Edit—Now has: ABS, BRAKE, TRAC OFF, check engine, and traction light.
  2. Mar 14, 2023 at 10:53 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I think its the right rear wheel speed sensor that is used for the speedo on automatic trucks. Someone will correct me if Im wrong
    Assuming no lights were on when you took it in, Id take it back to them.
    wilcam47, Jimmyh, Dm93 and 1 other person like this.
  3. Mar 14, 2023 at 10:54 AM
    drewnali
    Drew
    Florida
    Yeah. No lights were on when dropped off. I’ve read they can be installed backwards which I’m scared of. But totally overwhelmed at the moment.
  4. Mar 14, 2023 at 10:58 AM
    SR-71A
    Zack
    Southern Maine
    Id take it back for sure. They probably jacked up the speed sensor or stretched the wire harness while doing the bearing.
  5. Mar 14, 2023 at 11:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree with SR-71A... Right rear wheel sensor or cable.
    wilcam47 and drewnali[OP] like this.
  6. Mar 14, 2023 at 11:24 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The ABS Module will report vehicle speed from either of the rear speed sensors so odds are neither one of them are working, if the ABS light came on after you started driving that would suggest the sensors are electrically connected but not generating a signal.
    TnShooter and drewnali[OP] like this.
  7. Mar 14, 2023 at 11:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe the put the rear bearings on the wrong sides or something and the tone ring is positioned backwards.
    There's like a 10% chance that statement is accurate but I thought I remembered reading that is a possibility, putting the right onto the left and vice versa.
    drewnali[OP] likes this.
  8. Mar 14, 2023 at 11:32 AM
    drewnali
    Drew
    Florida
    The speedo worked for a bit- then I looked down and nothing.
    wilcam47 likes this.
  9. Mar 14, 2023 at 11:35 AM
    drewnali
    Drew
    Florida
    I read about that and freaked out a bit since I had bearings done.
  10. Mar 14, 2023 at 11:36 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Peek under the truck and see if maybe they didn't get the connector plugged in all the way.
  11. Mar 14, 2023 at 11:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This would be easy. But yeah take it back to shop
    drewnali[OP], SR-71A and Geeves77 like this.
  12. Mar 14, 2023 at 11:56 AM
    drewnali
    Drew
    Florida
    that’s what freaks me out.
  13. Mar 17, 2023 at 6:07 AM
    drewnali
    Drew
    Florida
    Got it scanned- I have a bad feeling the bearings were installed on the wrong sides.
    P0500 vehicle speed sensor
    C1411 RH rear speed sensor
    C1412 LH rear speed sensor
    C1445 steering angle sensor
  14. Apr 14, 2023 at 8:02 AM
    BigBoozer
    BigBoozer Member
    I have this same problem and have to make a 700 mile drive tomorrow… I should be good right?!
