ABS, Brake! & Traction Control lights on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WebberLander, Jun 2, 2017.
  1. Jul 1, 2017 at 6:56 PM
    #61
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Before purchasing any harness, I would check for +ve voltage and ground, two of each, at S22 connector.
  2. Jul 1, 2017 at 7:13 PM
    #62
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Those dash lights have been on for seven years, now.! Can't say as I give a shit, anymore
  3. Jul 1, 2017 at 8:49 PM
    #63
    WebberLander
    WebberLander [OP] Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    :anonymous::facepalm:Wow total brain fart by me. I have no excuse for doing that wrong, just didn't set the dial correct. I just Re-tested and got similar results but showed a little bit of voltage on the driver's side. Well below 7.5V.
    Driver's side:
    Passenger side:
    Can you help me understand this better? I crawled up to the S22 connector which is above the rear diff (right?). I unplugged it and attempted to measure voltage from the connection side (not from the harness just to be clear). I could only get .8 when I grounded the multimeter to the frame.
    I really appreciate all the help. Believe me I'm learning along the way and of course from any mistakes I make so by all means teach me where I'm going wrong. :bowdown:
    Sandman614[QUOTED] likes this.
  4. Jul 1, 2017 at 8:57 PM
    #64
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    He's saying check, on the side of the harness towards the front of the truck, pin 2 (RL) to frame and then pin 4 (RR) to frame. This will eliminate the rest of the harness forward to the ECU as a problem if you have between 7.5-12v on both of those pins.
  5. Jul 1, 2017 at 9:04 PM
    #65
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Ok got it. I wasn't getting a good connection I believe tonight when I tried this so I'll try again tomorrow morning. S22 is the connector that the rear wheel speed harness plugs into correct?
  6. Jul 1, 2017 at 9:12 PM
    #66
    10MGM
    2010 AC MGM 4x4
    Correct. You are testing the vehical harness to make sure there is voltage getting to the plug.
  7. Jul 1, 2017 at 9:33 PM
    #67
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Thank you. Ill try again tomorrow to get good readings and report back.
  8. Jul 5, 2017 at 5:30 PM
    #68
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Looks like voltage is getting to the plug. I tested both pins and got the same voltage. At this stage is it safe to assume the RL part of the harness is the culprit? I scanned the truck again after hooking the plug back into the rest of the harness that leads to the front of the truck and and cleared the RR wheel speed sensor fault. As expected the RL code did not clear.
    tomwil likes this.
  9. Jul 5, 2017 at 5:31 PM
    #69
    Sandman614
    Tim
    '06 SR5 Off Road
    I'd say so.
  10. Jul 5, 2017 at 6:42 PM
    #70
    10MGM
    2010 AC MGM 4x4
    Good work
    WebberLander[OP] likes this.
  11. Jul 7, 2017 at 8:58 AM
    #71
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Part is on its way. Ended up getting it from ToyotaPartsDeal.com for $93.66 shipped. Everybody locally wanted over $130 which is not that much of a difference but at this point I can wait a few more days. Excited to finally have this issue resolved once and for all. I'll also cut open the old harness once I have the codes cleared and determine where the wires are damaged.
    Thank you again TW for all your help.
    la0d0g likes this.
  12. Jul 7, 2017 at 9:05 AM
    #72
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Same stuff happened with mine, I think I hit it coming out of a rut. Same lights came on I bought a $15 wheel sensor off Amazon and it fixed it, it's been about 7 months with no issues
  13. Jul 7, 2017 at 9:07 AM
    #73
    bijick
    E
    Stl
  14. Jul 7, 2017 at 9:25 AM
    #74
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    This was the first step I took by simply replacing the wheel speed sensor but I could not get the fault code to clear via Tech Stream. So further diagnosis indicated that I am not getting enough voltage to the sensor itself so the problem lies in the harness. Before ordering a new harness I made sure (thanks to help from members here) that my issue wasn't in the wiring from the ECU at the front of the truck. After verify voltage is getting to the harness plug I determined the skid wire control harness needs to be replaced.
    I don't expect you to read through the whole thread but I've documented my diagnosis up to this point which helped me order the correct part(s) instead of just throwing money and parts are it.:thumbsup:
    bijick[QUOTED] likes this.
  15. Jul 9, 2017 at 9:18 AM
    #75
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    SUCCESS!!
    As suspected, the problem was indeed the harness. Upon removal of the entire old harness and inspection of it, I found both wires on the RL at the connector to the wheel speed sensor had a ton of play in them. After shinning an LED flashlight into the connector you could see exposed copper so from what I gather something got snagged right before the connector enough to break the connection inside. I don't know how it didn't break the original wheel speed sensor itself being that it is plastic but none the less, that was the problem.
    It was a great feeling finding that so I quickly installed the new harness, connected everything back up, scanned with tech stream and cleared all the codes. All the lights on the dash previously discussed in Post #1 are now off and truck is back to normal.
    A HUGE HUGE THANK YOU :bowdown::cheers::thumbsup:to @Sandman614 , @10MGM, @Bebop and the rest of you for contributing to this thread. For future readers I will update my original post with troubleshooting steps and the final solution including part numbers.
  16. Jul 9, 2017 at 9:19 AM
    #76
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Congrats on fixing the truck!!!!
  17. Jul 9, 2017 at 1:10 PM
    #77
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Updated Post #1 to include solution, part numbers and tools used. :welder:
    Drainbung, la0d0g and Sandman614 like this.
  18. Jul 9, 2017 at 5:13 PM
    #78
    Steevoreeno
    Steevoreeno Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
    I had these two lights on my 2015 TRD OR last Friday when I started my drive home from VT with camper in tow. I stopped for gas in NH halfway home and the were out when I started it up again.
    Guess I'll keep my eyes on it...
  19. Jul 9, 2017 at 6:05 PM
    #79
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Good you got that annoying problem resolved!
    Excellent troubleshooting work!:thumbsup:
  20. Jul 9, 2017 at 7:32 PM
    #80
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Was it both the "Brake!" and "ABS" lights that came on? If you have access to a scanner that can read the ABS module, that will be the best way to determine what fault code was logged when the lights came on.
    Keep in mind I had 3 lights with my issue.
    furi likes this.
