ABS, Brake! & Traction Control lights on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WebberLander, Jun 2, 2017.
  1. May 9, 2019 at 10:37 AM
    #121
    Jess-YODA-coma
    Jess-YODA-coma Active Member
    Jesse
    2010 double cab TRD SR5-Grey- Running 33's
    2010 double cab-grey, light bars, 3 inch lift, 33x12.x17. RDR wheels
    please tell me more about techstream. does it check ABS and traction control and airbag codes? looking for a code reader or cable that connects to pc to do all of this.
  2. May 9, 2019 at 3:56 PM
    #122
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yes it reads all computers in the trucks. It is the software the factory and dealers use. There should be usb options.
  3. May 29, 2019 at 7:52 PM
    #123
    wilson23
    wilson23 Well-Known Member
    Howdy,
    This thread is a gem! with the info within I tracked my issue down to a broken wire above the second connector which supplies power to the Passenger rear speed sensor. All good now, thanks fellas!
    Drainbung and WebberLander[OP] like this.
  4. Jul 9, 2019 at 6:29 PM
    #124
    WebberLander
    WebberLander [OP] Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Very glad this helped you!
    Drainbung likes this.
  5. Jan 10, 2020 at 9:29 AM
    #125
    DirtTaco
    DirtTaco Well-Known Member
    I have this issue but also my speedometer stopped working stays at zero. Are these issues somehow related? It all happened at the same time. No abs, traction co trim, cruise, no speedo and mileage is no longer climbing.
  6. Jan 10, 2020 at 9:38 AM
    #126
    wilson23
    Yes, they are alll related to the wheel speed sensors. I have had a single sensor not functioning and all related functions remain working. I’m wondering how many functioning sensors it needs to stay functionial. I have an 07 and doesn’t have a traction control
    DirtTaco likes this.
  7. Jan 10, 2020 at 9:40 AM
    #127
    DirtTaco
    Thanks for the confirmation. I read through the thread and didn’t see anyone mention that their speedo was out as well.
  8. Jan 10, 2020 at 1:28 PM
    #128
    DirtTaco
    Rock auto doesn’t have this part in stock- local Toyota dealer wants 270 plus tax and it’s back ordered from lordco. Napa can’t get it. Where are people getting this wiring harness? Part number 89516-04060
  9. Jan 10, 2020 at 5:16 PM
    #129
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    My right rear went out and had all the same indications. Mine was a bad wheel bearing.
  10. Jan 10, 2020 at 5:56 PM
    #130
    DirtTaco
    thanks- I’m in Canada and the closes ones are too far in the us.
    whatstcp[QUOTED] likes this.
  11. Jan 11, 2020 at 6:12 AM
    #131
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    This will only apply to autos, the manuals use a gear driven sensor at the transfer case output - not the wheel sensors. I'm guessing you're an auto.
  12. Sep 5, 2020 at 5:03 PM
    #132
    EBORSETI22
    EBORSETI22 Well-Known Member
    Evan
    New England
    '11 TRD Offroad
    TRD Exhaust Bed Mat Tinted Windows Tonneau Cover Cubby Bed Lights Reverse Lights Anytime Fog Mod Full OME Lift - 887s, LR UCAs, Dakars with D29XXL AAL MB TKO 17" Wheels 255/80r17 ST Maxx CMC Volant CAI with Scoop NFab Running Boards "Raptor" Grille Lights Ditch Lights 30" LED Hidden Light Bar On Board Air
    Incredible write up. Shocked to see how common this issue is. Tacomaworld saved me again from another dealer repair. I can only imagine what it’d cost to have them troubleshoot this and how many back and forth a it may have been.
    grateful for this forum yet again!
  13. Sep 12, 2020 at 9:18 AM
    #133
    Schlepy
    Schlepy New Member
    Shawn
    2009 Tacoma TRD Off-Road
    I am having the same issue, all the lights on. I had a wheel hub disintegrate on the passenger front and it broke the sensor. I replaced the sensor today and all the lights are still on. Checked for codes on the OBD II with zero codes found. Checked the wiring no knicks or cuts. Now I’m lost can can’t find an answer.
  14. Sep 21, 2020 at 12:21 PM
    #134
    wilson23
    have you reset the ABS codes via the pin jump method?
  15. Feb 15, 2021 at 7:28 PM
    #135
    Wheelin AZ
    Wheelin AZ New Member
    Jake
    2020 Quicksand Tacoma TRD Offroad
    I'm having this same issue on a 3rd gen with my front left ABS wire, I checked the wheel sensor harness and it's not getting power. I want to be sure the issue isn't coming from the next wire harness up that connects from the ABS/wheel sensor wire harness and goes in behind the grill, as I stretched both while lifting the truck. The issue is that I have been unable to get the harness loose at the upper portion to check the first section for power. I see one tab on the left of the harness, I am pressing it down and pulling and wiggling but it will not come loose. Any tips?
  16. Apr 12, 2021 at 6:57 AM
    #136
    jdvailco
    jdvailco Well-Known Member
    92 2wd reg cab 4cyl manual >> 05 Prerunner Access Cab 4 cyl manual >> 15 2wd access cab 2.7
    Hi all - I was able to test the wire that runs from the S22 connection near the differential to the front of the truck and confirmed continuity. However, I am not sure how to test the harness side. Do I test it from the s22 connector towards the rear brake and abs connector?? Or do I reconnect the harness at s22 and then disconnect the harness wire near the abs sensor / brake and test it there? I attempted to test the rear harness from the s22 connector but couldn't get the right angle and wasn't cure if I had the probes in the right place. I attempted to disconnect and lower the harness so I could see things better but got stopped by a rust bolt. Thanks everyone for the input.
  17. Apr 13, 2021 at 5:14 PM
    #137
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Leave the harness by the diff plugged in. Unclip your sensor and probe for voltage at the connector to the sensor. With the ignition on you should be getting voltage near 12V. Make sure to test both sides. If your voltage is good at both connectors then you most likely have a bad sensor. You’ll need a scanning tool that can read the ABS module to know how which side is throwing an error code.
  18. Apr 15, 2021 at 5:36 AM
    #138
    jdvailco
    Thanks so much for the clarification.
  19. Jun 30, 2021 at 4:01 PM
    #139
    mreen428
    mreen428 Well-Known Member
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Have these all lit up on my dash. Had my buddy read the code and it said driver rear wheel speed sensor. Replaced that and lights still on. Replaced harness and lights still on.
    I had no problems until I backed down my driver and the garbage can was under the truck that cracked the wheel speed sensor. I’m wondering if something else broke in the bearing that the sensor goes into?
    What is that part called?
    Thanks in advance.
  20. Jun 30, 2021 at 6:53 PM
    #140
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Did you clear the code or just replace?
