ABS Code help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Batman292, Jan 2, 2022.
  1. Jan 2, 2022 at 2:19 PM
    Batman292
    Batman292 [OP] Active Member
    zac
    2007 tacoma trd sport
    6in lift 35in tires half raptor lined
    Been lurking here for a while and cant find any info on the problem I am having. We got some snow here in Colorado the last couple days and with that i have a very sudden ABS light. When read the codes it shows are C0226, C0246, and C0256. I cant find much of any info on the cause of those codes. This is the weird part. Every time I start my truck there no codes or lights. i make the abs engage it works fine. After the brake is released i get the lights and lose ABS. i turn the truck off and on and no light and have ABS. Anyone ever delt with this?
  2. Jan 2, 2022 at 2:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Well, the C0226 is for the Brake Actuator.
    The flow chart is short and sweet. (Seriously)
    Clear Code, Drive truck.
    If code persists, Replace Brake Actuator.
    I don’t have any info on the 0246 or 0256 codes.
    Maybe someone else can help there.
  3. Jan 2, 2022 at 2:29 PM
    TnShooter
    Deogee
    STOCK
    Actually I do have info on the other 2.
    It’s the same diag.
    Clear codes, if they come back on.
    Replace Actuator.
    I know that doesn’t help, but that’s what it says:confused:
  4. Jan 2, 2022 at 6:20 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That seems to be the case but I'd still recommend checking powers and grounds at the ABS ECU before replacing it.
  5. Jan 2, 2022 at 6:24 PM
    Bishop84
    Bishop84 Well-Known Member
    ABS ecu code I always check for power and ground to the module itself. C0226 is always the module though, it means its awake to announce that it's dead.
    Otherwise it would be a U0### code.
    b_r_o, TnShooter and Dm93 like this.
  6. Jan 2, 2022 at 6:25 PM
    TnShooter
    Deogee
    STOCK
    Absolutely, I thought of that.
    But to be honest, I didn’t mention it because I honestly didn’t want to have to provide diagrams and pin outs. It’s been a long day. Let’s just say Water+Attic. We’ll leave it at that.
    Dm93[QUOTED] likes this.
  7. Jan 2, 2022 at 6:27 PM
    TnShooter
    Deogee
    STOCK
    Yeah, I saw that there was a code for relay or something.
    So, I figured it was “dead”.
    I believe the codes for power failure are 0273/74 and 0278/79?
    Dm93 likes this.
