ABS codes C1235 and C0278
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1265, May 20, 2024.
  1. May 20, 2024 at 11:55 AM
    TacoMan1265
    TacoMan1265 [OP] Member
    Fredy
    Toyota Tacoma SR5 2010
    Hello all. Got an issue with my 2011 Tacoma. Got both these codes on at the same time and the vehicle barely stops. Have to pump the booster for it to eventually grab the brakes. Check for voltage to the r/s wheel speed sensor and I’m not getting anything. Hoping it’s not the ABS module. Any ideas? Thanks.
  2. May 20, 2024 at 12:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the FRONT RIGHT wheel speed sensor.
    Then check the ABS No.2 fuse.
    No tools required for these.
    We will go from there after those checks.
