ABS codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilson23, Aug 14, 2020.
  1. Aug 18, 2020 at 12:22 PM
    wilson23
    wilson23 [OP] Well-Known Member
    found a crack in one of the positive leads on the harness upstream of connector S22. I was so hopeful but my hopes were crushed once again!
    b_r_o likes this.
  2. Aug 18, 2020 at 12:23 PM
    wilson23
    anyone have a good source for Koyo rear bearing assemblies?
  3. Aug 18, 2020 at 2:32 PM
    wilson23
    OK, i have done a continuity test from the S1 connector back to the S22 connector and there is connection! there is also a typo in the manual pointing RR1 to pin 46 while it actually resides in pin 45. I measured resistance and its right around .9 ohm so its good there.
    confirmed I'm using KOYO part# 2DACF044-6E which is accurate
    [/QUOTE]
  4. Aug 18, 2020 at 2:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    But were you stressing the harness when you got the .9 ohms? Pull it around and see if it spikes up
    What about the crack you mentioned above? A crack in the sheathing, the connector?
  5. Aug 18, 2020 at 3:41 PM
    wilson23
    I wasn't really able to stress the harness as I'm working alone and its tough to hold the probes and do anything else. I'll try to grab another set of hands.
    the crack was in the RR+ conductor above the S22 connector. I cut that area out and re-terminated the connector with no change
  6. Aug 18, 2020 at 4:50 PM
    wilson23
    Well, I am both delighted and ashamed to announce that this has been resolved thanks to my homie and TW member 5678TA! Turns out, despite pondering this for a good while, I pressed the bearings on the opposite sides thus orienting the sensors backwards. I am not a smart man.... I will drill and tap to mount the sensors correctly tomorrow as I would rather eat glass then remove and reinstall those bearings
    don't do drugs kids..
    yotaTom, TnShooter and Jimmyh like this.
  7. Aug 18, 2020 at 8:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Thanks for the updated information.
    TnShooter likes this.
  8. May 13, 2021 at 12:10 PM
    Augi
    Augi New Member
    Augi
    2006 tacoma extended cab 4x4
    Leveling blocks, rear spring packs
    When you pulled the axles out to replace the bearings where was your abs/ wheel speed sensor? Was it in front of the axle or behind the axle?
    I think I may have the same issue and when the bearings were pressed on my abs sensors were flopped right to left and left to right.....? So I think I have read that the sensors are directional and also right and left side specific. Just wondering if that is my problem.....? I have replace both sensors and rear abs wires
  9. May 13, 2021 at 12:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I know that the left side is located on the front of the spindle. Opposite side of the caliper. It will only bolt in one way.
    It is in front of the axle. The sensor has a flat side that faces towards the hub. (outside of the truck)
    Jimmyh likes this.
