ABS comes on randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fiend13, Apr 1, 2015.
  1. Apr 1, 2015 at 4:56 PM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Today on my way home from work my ABS light came on. I got home, turned the truck off, turned it on and the ABS light stayed off. This is the 3rd time this has happened. Anyone else have this problem?
  2. Apr 1, 2015 at 5:48 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Lots of choices, some easy, some not. Check the ABS sensor wires where they are exposed between where they leave the wire loom and reach the back of the wheel. They are hanging in the breeze, and I have had a couple over the years that were nicked or cut by road trash. If the wire has no guides, it can really flop in the wind and metal fatigue can cause it to break internally. Other things go from the simple to the bizarre. One wrong size tire or one very low in air pressure. I had a ranger where the magnetic ring came off the back of the hub and ABS went south.
    I'd just do a visual inspection first to see if everything looks to be in place. There is one sensor on every corner of the vehicle. All are underneath the car and can be snagged when going off-road, or just hit by trash on the road.
  3. Apr 1, 2015 at 6:17 PM
    Fiend13
    Chad
    Right on. I'll check the sensors. I checked them last time for a loose connection or loose wire and nothing. After it goes off it doesn't come back on for months. Might just be a loose connection.
