Abs, diff lock 4wd question
Discussion in '1st Gen. Tacomas (1995-2004)' started by HippieSabotage, May 7, 2015.
  1. May 7, 2015 at 9:49 AM
    HippieSabotage
    HippieSabotage [OP] Member
    Gary
    Pa
    2002 sr5
    Sorry if this has been covered however I have a question about abs. I've been plagued with the abs light. It'll come on and engage randomly on dry pavement (it's 80 degrees and dry today). I could careless about the abs system (I have replaced all 4 wheel speed sensors so I'm thinking theres a short or open current somewhere) stealership bill was astronomical. Those sensors cost anywhere from 2-260 each! I feel comfortable controlling my braking on my own. With that said, if I pull the abs fuse will will the rr diff lock still engage? 4wd work properly? I don't know if they effect each other. Any help would be appreciated.
  2. May 7, 2015 at 9:55 AM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    you can pull your ABS fuse and it wont effect your 4wd or diff lock.
    I sugguest if you know how to drive, pull the fuse.
    HippieSabotage[OP] likes this.
  3. May 7, 2015 at 10:11 AM
    HippieSabotage
    Gary
    Pa
    2002 sr5
    Thanks jake, appreciate the fast response.
    doyouevenprerun likes this.
  4. May 7, 2015 at 10:20 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    No Problem!
  5. May 8, 2015 at 10:04 AM
    cruiserkev
    cruiserkev Well-Known Member
    Kevin
    Lakewood, WA
    Will pulling the ABS fuse also turn off the ABS light on the dash? I had the same problem as the OP, spent a ton of $ at the dealership and had no luck fixing the issue. I just unplugged the wiring harness to the unit but the light stays on full time which is annoying. Thanks!
