ABS disable switch mod
Discussion in 'Performance and Tuning' started by rodstone, Feb 15, 2010.
  1. Feb 15, 2010 at 1:07 PM
    rodstone
    rodstone [OP] Well-Known Member
    Travis
    California
    08 2.7l 2wd
    I want to do the ABS disable switch mod to my '08 5 lug (no trac control or diff locker) and I'm trying to get an understanding of the system and what I need to do to make this mod work. I am loooking at these two diagrams (ABS w/o VSC and Stop light)
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d23.pdf
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d12.pdf
    My understanding is that the ABS pump is only activated when the ECU receives an input signal from the brake light switch. So by interrupting the input signal from the brake switch to ECU with a switch will disable the ABS pump and ECU from monitoring wheel speed and control of skid? I want to be 100% sure and receive input from others before I go cutting and splicing wires. TIA
