ABS disable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ramitdammit, Dec 20, 2008.
  1. Dec 20, 2008 at 3:05 PM
    ramitdammit
    ramitdammit [OP] Member
    Apple Valley CA
    06 4x4 dbl cab snugtop super sport
    Is there anyone out there that has used an OEM style swtich (fog light swtich or diff-lock swtich etc.) instead of an autoparts store toggle swtich as a disable for the ABS. If so do the existing blank swtich incerts just pop out of the dash?
  2. May 21, 2009 at 7:36 AM
    cottonbroker
    cottonbroker Member
    Indiana
    TRD extended cab
    Any luck disabling the ABS? My ABS has an Issue and I'd Like the option of turning it off.
    Any easy way to describe which wire you're slpicing to put in the disable switch?
    Thanks
  3. May 21, 2009 at 10:15 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Off road it can be deteimential an kicks on when it doesn't need to.
  4. May 21, 2009 at 10:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2
  5. May 21, 2009 at 3:58 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  6. May 22, 2009 at 7:12 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    There is a fuse for it, just put a switch in line before it. You'll get all sorts of idiot lights on the dash though.
    I had some issues with my gas miser corolla after 150k that I just clipped the fuse to get the damn abs to not work.
  7. May 22, 2009 at 7:13 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    there's a small connector on the left side of your battery, towards the bottom. uplugging it will disable your abs. you may have to disconnect your battery once you plug it back in to get rid of the dash light...been so long since i've done it that i can't remember if it resets itself. not as convienient as a dash switch, but gets the job done.
  8. May 22, 2009 at 7:31 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ABS is better for people who aren't used to advanced driving techniques. It takes a lot to keep a cool head in a skid and remember threshold breaking, not to mention incorporating avoidance steering into the mix. ABS takes the breaking part of it and does that for you so you can focus on steering. However, ABS is not as effective as threshold breaking to those who know how, and can utilize it properly.
  9. May 26, 2009 at 8:08 AM
    cottonbroker
    cottonbroker Member
    Indiana
    TRD extended cab
    Thanks for all the replies.
    I drive with distance between me and the car ahead and am comfortable doing the same on Ice.
    To fix this the dealer is surely going to want $1000 so I just need to shut it off for now so it doesn't CAUSE AN ACCIDENT! Which I came much closer with the ABS kicking on than I ever did with out it.
    If it was as much as cleaning them and they worked again I'd be all for ABS but just like all the other bells and whistles on cars today the repair often isn't worth the use.
    I noticed the fuse in the ABS bos and will try that. I'll also try cleaning the sensors first but something tells me that won't help. I'll also check my bads to see if there is any significant issues there. I don't know much about he back breaks and adjusting them so I'll have to wait until I learn that trick.
  10. Feb 10, 2010 at 6:15 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    so abs blows in the snow.I FUKN HATE IT BIG TIME!!!!!!!!i just want to get rid of it forever.is it that simple of pulling the fuse without messing with anything else???maybe unplugging something??i dont want 300 lights on the dash lit up.
  11. Feb 10, 2010 at 12:12 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    Bingo. I am one of those who learned using threshold. I have driven a variety of ABS systems and I find that the current evolutions seem to activate long before threshold (which means long before lockup). ABS is alright for the untrained drivers panic stop on perfectly dry pavement. In ANY other conditions ABS scares the hell out of me, especially winter or low traction conditions.
    I wish that there was more emphasis on driver education and stricter licensing criteria rather then the plethora of "safety" features on new vehicles. ABS, blind spot indicators, backup alarms, auto park, proximity decelerate, etc., etc. IMO most systems are an attempt to make up for a general lack of driver intelligence. If everyone was required to show proof of attending quality drivers training in order to get a license then these systems wouldn't be needed.
    Sorry a bit off topic. My point is just that to many getting rid of the ABS makes perfect sense.
  12. Feb 28, 2013 at 1:44 PM
    dunwurguy
    dunwurguy Member
    bill
    Canada
    2011 tacoma 4x4 sr5
    There are 3 fuses related to the ABS on my 2011 Tacoma , Everyone says just pull the fuse to disable the ABS .... Well ... Which one ? I must disable before I get in an accident . This is the most dangerous breaking system I've ever had on any truck I've owned ....
  13. Feb 28, 2013 at 2:09 PM
    sde780
    sde780 Well-Known Member
    Do everyone on the road a favor and leave your ABS as-is.
  14. Mar 1, 2013 at 6:37 AM
    dunwurguy
    dunwurguy Member
    bill
    Canada
    2011 tacoma 4x4 sr5
    sde780 . If you read the posts on here you will note that the ABS is a big problem on the Toyotas . To say " leave as is " certainly is not the answer we're looking for . If you drove a truck with this system I think you would change your tune in a hurry . But thanks for answering my post ....
  15. Mar 1, 2013 at 9:18 AM
    sde780
    I do drive a truck with this system. My tune is not changing - 99% of people on this forum will be safer with ABS on in a dangerous situation.
  16. Mar 1, 2013 at 9:20 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I spliced a wire at the abs computer and used a switch to turn it off...works great
  17. Mar 25, 2013 at 8:08 AM
    Jaws9760
    Jaws9760 Active Member
    Northern Idaho
    2013 V6 4x4 DCLB TRD Sport MagGrey
    Bed liner shovel mount, head rest vertical rifle mount, console .380 holster. Tailgate hose clamps & washers. Green LED dome light, Disabled seat belt chime.
    I'd like to disable ABS by pulling a fuse or fuses. I know ABS no.1 and ABS no.2 are in the engine fuse box.
    Has anyone disabled their ABS this way? I found one thread where a fellow pulled both fuses but he said he got lots of nasty lights and sounds, ended up putting one fuse back. I'd be more confident if I heard from more fuse-pullers.
    I really don't want to do a switch mod. The wiring scares me and I don't give a damn about having a switch, I just want the ABS off forever. Thanks in advance.
  18. Mar 25, 2013 at 8:14 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Ftfy big guy
  19. Mar 25, 2013 at 9:13 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Well that's embarrassing. Thank you for spell checking a 4 year old post...dick faced penis sucker.
  20. Mar 25, 2013 at 9:16 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
