ABS DTC Codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FoxxOhmer, Jan 6, 2021.
  1. Jan 6, 2021 at 2:50 PM
    FoxxOhmer
    FoxxOhmer [OP] New Member
    Foxx
    Texas
    2009 4x4 base, 4.0L, 6 speed manny
    Toyo A/T Open Countrys
    Hello everyone,
    The traction control and ABS lights recently popped up on my dash. I read the codes and got C1241 and C1246 which are low/high power supply voltage and master cylinder pressure sensor malfunction respectively.
    One of the overlapping causes is faulty wiring but my buddy tested the leads from the ABS actuator to the battery and everything seems to be getting sufficient power. So it doesn't appear to be damaged wiring.
    I guess long story short, I don't know enough about that system to determine what is causing what and there seems to be several causes for each code. The common denominator, though, is the ABS actuator which I'm hoping to not have to replace cuz them ain't cheap.
    Any help would be greatly appreciated! Thanks in advance.
  2. Jan 6, 2021 at 4:47 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have the ABS/Master Cylinder assembly or the separate standalone ABS?
  3. Jan 6, 2021 at 6:10 PM
    FoxxOhmer
    Foxx
    Texas
    It's a separate ABS module.
  4. Jan 6, 2021 at 6:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I would diagnose the C1241 first and see where that goes before going after the C1246 but I would recommend using a test light (connected to battery ground to check power and connected to battery positive to check grounds) instead of a voltmeter as a voltmeter will not tell you if the wire can carry current.
    tirediron likes this.
  5. Jan 6, 2021 at 7:04 PM
    FoxxOhmer
    Foxx
    Texas
    That was kind of my thought too, the 1241 could be causing things inside the module to read faulty. Thanks for the tip! And the circuit diagram. I'll look into this.
  6. Jan 6, 2021 at 10:17 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You most likely have a basic electrical problem like loose connection, bad ground, weak battery, corrosion, pinched harness, dying alternator, etc. Figure out the low voltage and likely that fixes everything.
  7. Mar 9, 2021 at 7:35 PM
    Gst93
    Gst93 Member
    North Bay California
    2012 Tacoma Sr5 4x4
    Did you ever figure out c1241? Been driving me crazy
  8. Mar 10, 2021 at 2:28 PM
    FoxxOhmer
    Foxx
    Texas
    I did. Mine was a bad ground connection. Found it hiding behind my washer fluid reservoir. Cleaned up the connector and the contact surface and it went away immediately.
