ABS Error Codes - 34 & 48
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Feb 25, 2011.
  1. Feb 25, 2011 at 7:43 PM
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    ABS light illuminated this morning on my way to work. Pulled the codes tonight and they are:
    34 - Left Rear Wheel Speed Sensor Signal Malfunction
    48 - Open Circuit in Rear Differential Lock
    Everything underneath looks normal at a quick glance, but am going to put the truck on a ramp this weekend and clean the affected sensor and trace the wiring to ensure all the connections are good. Brake fluid level is topped off to the max line.
    Anyone experience anything similar?
    Are the four speed sensors interchangeable front left/right, front/rear? If I could swap the rear sensor for a front one, and the code changes - I'll know the sensor was the culprit.
  2. Mar 2, 2011 at 6:28 PM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    any luck?
  3. Mar 2, 2011 at 6:49 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check to make sure the sensor hasn't moved from it's intended position, or it will not produce a signal.
    Unplug the wires from the computer and sensor/diff and check for continuity in the sensor/diff.
    Not sure if sensors are interchangable.
  4. Mar 3, 2011 at 9:51 AM
    Fortech
    CANADA
    Sensors are interchancable from front to rear on the same sides (front left can be subsituted for rear left).
    It was a very stormy weekend, the garage was full with no room for the truck, so I didn't dig any further into the problem. Upon starting the truck Monday morning to go to work, the light was no longer illuminated.
    As the saying goes, If it ain't broke, don't fix it...
