ABS Fuse
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekp, Dec 28, 2009.
  1. Dec 28, 2009 at 4:52 PM
    derekp
    derekp [OP] giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    The under hood fuse block on my 2001 V-6 has a spot for an ABS fuse but no fuse in it. The cover states that there should be a fuse there but it is empty. (The other empty spots are blank on the fuse block legend.) Should it be empty or do you think it was removed for a reason? Thanks!
    Derek P
    Germantown, MD
  2. Dec 28, 2009 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your truck may have only come with a rear ABS.....Might not need a fuse.
  3. Dec 28, 2009 at 5:26 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    My truck doesn't have any ABS, but the fuse box still has a open spot for it as well as a label on the cover. Do you have ABS at all?
  4. Dec 31, 2009 at 9:46 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    ABS wasn't standard in the 2001 model year - it was an option.
  5. Dec 31, 2009 at 9:49 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I pull my ABS out every time I go off road
  6. Dec 31, 2009 at 9:55 AM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    so let me get this straight...i pull the fuse and viola, i am with out ABS and its all back to normal like old school braking?
    I can not believe i've never thought of this...and its so simple
  7. Dec 31, 2009 at 10:17 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  8. Dec 31, 2009 at 10:38 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I've heard of people making in cab switches to turn it on and off too.
  9. Dec 31, 2009 at 6:06 PM
    gjbonner
    Guy
    Northern Idaho
    That in cab switch would probably be nicer. do you have a reference maybe? I wonder how you would go about that....
    Edit: Googled this on a chevy forum ABS Switchseems like the concept should be pretty much the same for any vehicle i guess.
  10. Jan 1, 2010 at 7:54 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I think I saw the DIY instructions on a website for my old vehicle, fullsizebroncos.com. It was pretty common for those guys to either make switches or disable ABS all together. I agree that it should be pretty much the same for any vehicle. I'm certainly not an electronics expert but I can't imagine being more than identifying the proper wires, disconnecting the battery, and tapping in appropriately rated switches and wires that reach the cab. It should be easy to keep the cost down to about $10 too. If you do it and make a nice write up with pictures, I bet you could get yourself a spot on the cheap mods page (if it's not there already).
    My Bronco was disabled all together because most of its use was off road. I can't bother doing it to my Taco, because in doing so it would also disable my ATRAC (among other traction systems). ATRAC rocks, so I definitely don't want to lose it.
  11. Jan 1, 2010 at 9:13 AM
    gjbonner
    Guy
    Northern Idaho
    yeah i'm in the process. i found an inline 50 amp fuse holder so i should be able to work it in the fuse box under the hood. i didnt like how they went in the cab's fuse box because it turned off other things like cruise control and some other things... i would rather it be only affecting the ABS. looks like that 50 amp fuse under the hood is where its at.
    one question though..in the pics you reall couldnt tell what wires connected to what.. i take it the hot part of the fuse runs to the inline fuse wire and then to the pos part of your switch. then form the not hot part of the fuse box a wire just goes straight to the toggle. This is how i take it. maybe ill burn the toy down trying to find out hahahahah
  12. Jan 1, 2010 at 9:20 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Again, I'm far from being an electrician but try identifying and double checking the wires by checking current with power on, off, fuse in, fuse out, etc. to make sure you're tapping into the right ones.
  13. Jan 1, 2010 at 9:21 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
  14. Jan 1, 2010 at 9:25 AM
    gjbonner
    Guy
    Northern Idaho
    Awesome. thanks. i searched for abs the other day and only found a few other threads but never knew it was in there.
  15. Jan 1, 2010 at 9:34 AM
    gjbonner
    Guy
    Northern Idaho
    hmmm that is a whole different route than others have gone. what would be the difference of doing that mod or the "inline fuse" mod from the 50 amp abs fuse under the hood to a switch? just looking for advice. seems like less wire running around and there is a fuse being used.
  16. Jan 1, 2010 at 10:37 AM
    derekp
    Derek
    Grand Forks, ND
    I am not sure if my truck has the ABS option...it is a 2001 V-6 5 spd TRD 4x4...
    Pros/Cons of having the ABS fuse out for off-roading?
  17. Jan 1, 2010 at 9:09 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ with ABS in during off roading your brakes wont engage because the computer assumes your wheels are locking. You'll slide for a long distance. With ABS off, in sandy or heavy dirt terrain, heavy braking is more effective because a) ABS wont cut off the brakes and b) when your wheels lock up, it will dig into the ground, effectively stopping your truck in its tracks...its really fun!
