ABS: Good Story
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Mar 2, 2012.
  1. Mar 2, 2012 at 11:30 AM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Ok I hear all these bad stories about ABS. I know it has its drawbacks especially offroading and in snow but here's an ABS praise.
    I was driving to work and approached an intersection where cars are suppose to yield to the lane I was in. Car didn't yield, I was going about 25-30 mph and so was the other car. He came head on veering to my left and I hit the brakes.
    Tires started to screech and my truck started pulling to the left right into the other car. ABS kicked in, straightened me out and I was able to avoid the douche bag.
    I probably would have been able to stop in time without ABS and avoid the accident but it proved to me that ABS does do its job sometimes. Allowed me to keep control of the truck and maintain steering.
    Anyway that's alllllll
  2. Mar 2, 2012 at 11:36 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    try em on hard packed snow!
    Glad to hear you and yer truck are ok!
  3. Mar 2, 2012 at 11:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ABS is great on dry pavement and has saved me once but has more than once nearly caused wrecks on snowy roads.
  4. Mar 2, 2012 at 11:41 AM
    forana
    Kaneohe, Hawaii
    well I live in Hawaii so snow isn't a big concern...
  5. Mar 2, 2012 at 11:43 AM
    gooch14
    Kyle
    Michigan
    Yah sorry, I wasn't trying to be a dick. I think Zombie clearified me perfectly.
  6. Mar 2, 2012 at 11:47 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you were " pulling to one side and ABS straightened you out " sounds like maybe what you actually experienced was the VSC kicking in .
    Was there a beeper beeping when it kicked in ?
  7. Mar 2, 2012 at 11:56 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    The ABS in my truck could had killed me one time. That system is flawed and needs to be checked out by the Toyota engineers.
  8. Mar 2, 2012 at 1:10 PM
    forana
    Kaneohe, Hawaii
    Could have been the VSC but there was no beeping. happened so fast. All I know is that once the ABS kicked in, I was able to regain control of the truck.
    Gooch, I knew what you meant. I agree that ABS is good on dry pavement but awful on anything slippery.
  9. Mar 2, 2012 at 1:15 PM
    OZ-T
    Peter North
    British Columbia
    Not VSC if there was no beeping
  10. Mar 2, 2012 at 2:34 PM
    inouk
    inouk Well-Known Member
    Did you felt some pressure on pedal brake and heard some "grinding" noises? If yes, it's ABS :)
  11. Mar 2, 2012 at 3:28 PM
    OZ-T
    Peter North
    British Columbia
    VSC creates the exact same sensation in the brake pedal :)
  12. Mar 2, 2012 at 3:31 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Threshold braking is the way to go. Your in control. Faster response than abs and don't lose control. Abs works sometimes yes. However the driver will always be able to do what it does
  13. Mar 2, 2012 at 3:33 PM
    crazyrzr85
    crazyrzr85 So many b!tches, so little time...now back to TW!!
    ErIc
    W.PA
    10 Tacoma TRD DBL Cab(Totaled) 09 DCSB OR BSP
    Rugged Ridge front mats and Husky rear mat, bed mat, vent visors, bug shield, pine scented tree on mirror
    I am thinking seriously about doing the ABS kill switch mod, using only in snowy conditions tho...
  14. Mar 2, 2012 at 4:32 PM
    forana
    Kaneohe, Hawaii
    rdd11, I agree that the driver should be first in controlling his truck. HOWEVER, after much thought about this I'm not so sure.
    This last incident happened FAST. I have decent reaction times and it was impossible for me to anything other than slam on my brakes. There was no time to think about threshold braking or preventing slip, just mash my brake. You can argue that I did have time to think and I need to be a better driver, go ahead.
    So my thinking now is that a truck that can do some thinking for you is a good thing. Of course there will be faults but it has its uses.
    So
  15. Mar 2, 2012 at 5:00 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Dammit, I misplaced my "I call bullshit" pic.
    Found it.
    In my experience in responding to high speed nasty wrecks we've seen an awful lot of solid skid pads into the collision. Lots of people panic and lock up the brakes in a "true" emergency stop.
  16. Mar 2, 2012 at 5:06 PM
    inouk
    Oh well. I did drive a car with a stability control, it was called ESP. It was great but it didn't felt like ABS, it was two completely different system. I mean, ESP doesn't lock your wheels, it simply helps you to put the car where you want to go. I must say that it works very well, at least, on a Jeep Patriot, my previous car. They were making sounds indeed, when in fonction.
    On a side note, did you know that ESP, VSC and alike will be mandatory for 95% cars built and sold in the USA starting from this year.
    Canada created same kind of law to make it mandatory for cars that are built after September 2011.
    But not ABS, they held off, especially NHTSA :D
