ABS has a mind of its own...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Feb 25, 2023.
  1. Feb 25, 2023 at 9:11 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Thanks for that info and procedure! It seems like the earlier 2nd gens are like the Galactica... plenty of computers, not necessarily all networked together.
    Whatever manual you pulled that from is awesome!!!
    I'll try clearing the codes tomorrow. Then see what codes if any pop back up after a short drive.
  2. Feb 26, 2023 at 10:35 AM
    kidthatsirish
    So I cleared the codes and went for a drive this morning. Slow speeds and plenty of turns. ABS pump kicked on randomly throughout the drive until the ABS light illuminated again.
    Pulled the code and only 31 showed up this time.
    Hesitant to pull the sensor and go looking in this weather as it would likely break I imagine and I still don't know for 100% that sensor is the issue. I'll take the wheel off this afternoon and do a visual inspection and start following wires. I think I'll also see what connectors I can find and check them for corrosion. Unfortunately I live in Omaha Nebraska now which has the most ridiculous DOT I have ever seen. They spread a ridiculously high amount of salt all over the roads to the complete detrimental effect of it's citizens, vehicles, and likely nearby crop land.
  3. Feb 27, 2023 at 11:35 AM
    kidthatsirish
    So after driving around again today the ABS light turned itself back off again.:confused:. I just don't get it....that being said I am leaning towards that sensor but I don't just want to shotgun parts at a truck.
    Anyone else have any tips?
  4. Feb 27, 2023 at 5:20 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Without a scan tool to read ABS data to see what the sensors are actually doing your kinda stuck with guessing.
    Since you live where they salt the roads rust jacking is another possibility, you could look at the sensor and see if it looks like rust has grown under it and forced it up.
