Abs hiss sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ricetaco69, May 16, 2021.
  1. May 16, 2021 at 2:51 PM
    Ricetaco69
    Ricetaco69 [OP] Member
    07 White V6 SR5
    So I’ve notice today my abs module makes a hiss noise when I apply brakes. Engine on or off. Brakes work but makes me worried imma wreck due to brake failure
    Tacoma 07 v6
  2. May 16, 2021 at 5:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do your brakes work as they should?
    Do you have an ABS Light on the dash illuminated?
    Do you have a vacuum booster ( it sounds like you do )?
    If so it is normal.
  3. May 16, 2021 at 7:43 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Abs sensor? Is it your break booster going?
  4. May 17, 2021 at 8:30 AM
    Ricetaco69
    07 White V6 SR5
    I have a vacuum booster. Works perfectly. It’s the module on the passenger side above the air cleaner. No abs light. Brakes are working fine.
  5. May 17, 2021 at 8:31 AM
    Ricetaco69
    07 White V6 SR5
    No abs light. Sounds like a leak from the abs module above the air cleaner
    suaveflooder[QUOTED] likes this.
  6. May 17, 2021 at 3:48 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What is it leaking? If there was a leak it would be obvious, there would be brake fluid everywhere. There are no vacuum lines going to the ABS.
  7. May 17, 2021 at 3:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You can completely disable the ABS System and all that will happen is the brakes will work like regular brakes with no ABS. ABS is a fail safe system. Now it is another story if you have a brake fluid leak.
  8. May 17, 2021 at 4:25 PM
    Ricetaco69
    07 White V6 SR5
    It just makes a hiss sound. Seems to work fine just it’s a very noticeable sound. No leaking
  9. May 17, 2021 at 4:26 PM
    Ricetaco69
    07 White V6 SR5
    I will try to upload a video of it
  10. May 17, 2021 at 4:29 PM
    Ricetaco69
    07 White V6 SR5
    https://youtu.be/AA9R9sC5Uz8
  11. May 17, 2021 at 5:19 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Can you hear it in the cab while driving?
    No ABS Light and the brakes are working normally, I wouldn't worry about it.
  12. May 17, 2021 at 5:19 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    E3Cu_MpaaVQD02dPhWjBZesZrbDy76Rq5ZuiAp9L_a7f4597261d49f8da94a27397f82e13ef4e35f2a.jpg
    Torspd and Jimmyh like this.
  13. May 17, 2021 at 5:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  14. May 17, 2021 at 10:18 PM
    Ricetaco69
    07 White V6 SR5
    Okay. Can hear it in the cab a little. Thanks for the help!!
