ABS Issue is starting to bother me.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian, Sep 22, 2011.
  1. Sep 22, 2011 at 9:20 AM
    brian
    brian [OP] Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I've had a very random ABS issue from some the start owning my truck. It only happened maybe once every couple months, IF that. Now its getting more frequent.
    Occasionally, when coming to a stop, you can feel the ABS doing something. My pedal gets a littlle squishy and brake performance decreases, very much like when the ABS goes off in a skid condition.... however I am on dry pavement in the middle of california. Its starting to bother me because I am worried that I'm about to get in trouble if I really need those brakes one day and I don't have the full braking power.
    I am a pulse braker, I do not 'ride the brakes' to a stop like some people do. I could disable ABS, but I'd rather have it. Brakes have been bleed multiple times over this vehicles history and haven't affected it. I can only suspect this might have something to do with the vaccuum system. I still get the 'squishy brake pedal' tacoma lurch thing when the AC kicks on, and I hate to think that this is related, but I believe it is.
  2. Sep 22, 2011 at 9:50 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Probably need the system recalibrated. ask sierrahsky about it. he went through some problems with his.
  3. Sep 22, 2011 at 9:59 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Are you lifted ?
  4. Sep 22, 2011 at 10:03 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    ^^ It could be getting confused b/c of your 33s
  5. Sep 22, 2011 at 10:09 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I had the same issue in my tundy with stock tires. I found that switching to a ceramic pad solved it. I think the stock pads (if they were stock) had too much grip on the rotor.
  6. Sep 22, 2011 at 10:22 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    If your lifted, I think your problem is that your trying to stop a massive rotational force(big tires) with such a small unit(aka the brakes), so I believe your fluid pressure is expanding so fast in your lines from the increased work it has to do..the squishy feeling is your lines expanding and contracting. Try stainless steel lines? Braided?
    :confused:
  7. Sep 22, 2011 at 10:56 AM
    brian
    Elizabeth City, NC
    I wont dispute that it probably has to do with my tires to some extent. The brakes have been bled many times throughout this trucks history, always been an issue.
    If I was to slam on the brakes, they've always seem to be there. I only notice it when I come to an easy stop, usually when I get down to about 20 mph, you can feel the pedal pulsing a bit, and drop somewhat to the floor. If I really needed to stop at this point, I probably wouldn't be able to. The first time it ever happened to me a few years back, I was coming down a hill and actually rolled out into the street a little. Extremely bothered by it then, but it never happened again afterwards, for a long while that is.
    Christian, you say you have the A/C lurch but you dont feel it in your brakes. I wonder if this is because you don't have the same size tires as I do.
    I remember awhile back, someone added an extra vacuum canister or something to that extent and solved the A/C lurch issue for them. Does anyone know where this thread went?
  8. Sep 22, 2011 at 11:02 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Brian, are you actually hearing/feeling the ABS kick in? There are situations when you're coming to a stop that the pedal gets softer and drops a little as if you lost some pressure in the lines or some vacuum. It's the same feeling as when sitting at a stop and you feel your pedal sink some but instead happens when driving and using the brakes. I know of two places I drive where it does it regularly, but nowhere else. Mine's done it for years (I've read a few threads years ago where people experienced the same thing and we all figured it was normal). Are you describing this or something else entirely?
  9. Sep 22, 2011 at 11:17 AM
    brian
    Elizabeth City, NC
    I'm not hearing the springy sound of the ABS, but I'm feeling the pulse in the pedal. As you describe it, losing pressure in the lines, its EXACTLY how it feels. Honestly, if I didn't feel the pulse in the pedal, I would think my brakes needed to be bled. I've heard the lurch issue so many times, but I've never heard of it happening while on the move. It does feel similar.
  10. Sep 22, 2011 at 12:06 PM
    05Moose
    Jim
    I don't think when I lose that little vacuum while braking that it pulses. It's more of a situation where the pedal is firm for awhile, then suddenly it sinks another inch (probably only half an inch but feels like an inch) and then is firm at that lower point. If yours is pulsing that does sound like ABS.
    I know at least the fronts work independently from the rear (have that happen in the snow in winter depending on how fast I try to stop), and when that happens it's not the loud ABS grinding sound nor does the pedal do it big pulsing like when all 4 tires are getting ABS. So now it just occurs to me that I bet all 4 wheels are independent in that regard. Could it be that you have a bad contact on one of the connections on one wheel? Have you tried unplugging all 4 sensors and plugging them back in again?
  11. Sep 23, 2011 at 9:29 PM
    brian
    Elizabeth City, NC
    Jim, if you ever come down this way, call me, I'll let you go for a ride and see if we can reproduce it.
  12. Sep 23, 2011 at 9:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My truck does that at the same two places in town almost every time. One spot has a piece of steel in the road where the road meets with a bridge. I have not yet figured out what's so special about the second spot. It's definitely a disconcerting feeling, but I have never felt like it's not going to stop, just feels like I'm not the one deciding that.:rolleyes: I think that if the ABS didn't kick in, the tires would just lock up and the truck would slide. I have had similar situations in other brand vehicles. I don't think there's anything wrong with my truck.
  13. Sep 24, 2011 at 3:40 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Our 2010 has done this at least once.
    Slowing for a red light, truck started slowing, without excessive pressure or locking the wheels, normal braking, suddenly the pedal dropped what seemed like a lot and braking was diminished. The anti skid did not pulse or actively engage.
    For some reason or luck, the location and traffic in the opposing lane was just right and we stopped next to the car that was stopped in front of us. Yes we would have rear ended the car in front of us.
    Took it back under warranty, no faults found or defects noted.
    I accepted it as a fluke (assumed I had screwed up) after the dealer releasing it from service.
    Problem being I did feel the pedal drop, at which point I applied more brakes with minimal results. Did not panic, just reacted and avoided a collision. As you phrased it, it felt as if braking pressure was just dumped suddenly.
    This is with stock oem tires and no lift.
    I realize this is no answer or help. Sorry. I now just allow more than a reasonable amount of stopping room, in an emergency stop not sure what too expect. Posting this, maybe I should find a section of road where I could try a hard panic stop and see what to expect. Kind of practice it a few times per say.
    Best of luck with it.
    PK
  14. Sep 24, 2011 at 4:40 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    My 2007 had this problem, I switched my pads over to ceramic, it didnt seem to help. So I can save you the expense there. My pedal felt like it was hard, almost like you felt like you had to put a lot of pressure to stop vehicle. I never did get it fixed.
    My 2011 feels like a completely different braking system. Not sure if its just the earlier models or what.
