ABS issues on icy roads and tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fightnfire, Jan 6, 2015.
Have you experienced ABS issues on icy roads?
Poll closed Feb 5, 2015.
  1. Stock tire size - I have NOT experienced ABS issues on icy roads
    28.7%
  2. Stock tire size - I HAVE experienced ABS issues on icy roads
    35.7%
  3. Oversized tire - I have NOT experienced ABS issues on icy roads
    20.9%
  4. Oversized tire - I HAVE experienced ABS issues on icy roads
    14.8%
  1. Jan 6, 2015 at 6:28 PM
    Fightnfire
    Fightnfire [OP] Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    This poll is an attempt to get some basic data about who is and who isn't having ABS issues. After some light searching it seems that it is a somewhat accepted idea that a larger tire size can cause ABS issues including over sensitive and early engagement of the ABS system.
    Stock size tires - I have not experienced ABS issues on icy roads
    Stock size tires - I have experienced ABS issues on icy roads
    Oversized tires - I have not experienced ABS issues on icy roads
    Oversized tires - I have experienced ABS issues on icy roads
    2005-2014 Factory size tires:
    215/70 R15
    245/75 R16
    265/70 R16
    265/65 R17
    255/45 R18
    Please use these STOCK sizes to base your selection off of, anything larger is oversized.
  2. Jan 6, 2015 at 6:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine has happened over 3 sizes
  3. Jan 6, 2015 at 6:31 PM
    Fightnfire
    Marysville, WA
    Including stock?
  4. Jan 6, 2015 at 6:32 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I have oversized 265/75-16. ABS sucks as usual. Not sure about it being worse.
  5. Jan 6, 2015 at 6:39 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Have not had any problems. 265/70 R16
    Toyo at2
  6. Jan 6, 2015 at 6:43 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I feel it's a tire issue. I had issues with the stock tires. I switched to Goodyear Authority 265/70/17 M&S's and never had an issue in snow. This year, I put on studded Firestone Winterforce snow tires to, hopefully, take care of the problem on ice.
  7. Jan 6, 2015 at 6:59 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I've had problems with mine. I guarantee it has nothing to do with tires though.
    ETA: Stock tire size.
  8. Jan 6, 2015 at 7:01 PM
    Fightnfire
    Marysville, WA
  9. Jan 6, 2015 at 7:07 PM
    OZ-T
    Peter North
    British Columbia
    Yep
  10. Jan 6, 2015 at 7:09 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Of course, the stock tires are horrible!
  11. Jan 6, 2015 at 7:10 PM
    Fightnfire
    Marysville, WA
    The point isn't that the stock tires are horrible, the point is that while running them the ABS acted up.
  12. Jan 6, 2015 at 7:11 PM
    PA452
    Western PA
    I don't care what tires you have. If you have three wheels on dry pavement and one wheel hits an icy patch while you're on the brake at a very slow speed, the ABS should not kill your braking power to all four wheels. And mine has in the past. Not always repeatable, but it's done it many times in the 8 years I've owned it.
  13. Jan 6, 2015 at 7:11 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I agree the system is sensitive. But, if you get tires that will grip, you can compensate for the sensitivity.
  14. Jan 6, 2015 at 7:11 PM
    Fightnfire
    Marysville, WA
    I should have had a 5th option, ah well.
  15. Jan 6, 2015 at 7:12 PM
    Fightnfire
    Marysville, WA
    You should pick stock - had issues..
  16. Jan 6, 2015 at 7:20 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Last winter OZ warned us all about this problem. Last winter I was all factory,, bran new. Dam near took my buddy's bumper out, not to mention my front end!!!! Left front on dirt, the other 3 on ice. Truck gave up on the ((traction tire), which would have stopped the truck easily, wasn't going 2-5 mph. Wouldn't stop! I missed him by inches! Should have listened to OZ better back then. Dam near got me killed today!!!
  17. Jan 6, 2015 at 7:42 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yeah, I get where you are going with it. I'm slightly over stock, so "oversize" for me, with issues in slippery conditions at low speeds. I bought the truck used and haven't run stock size in slippery conditions, I put new Duratracs on the first fall before it snowed. I don't think the size much of a factor though, since larger tires will allow more circumferential difference in "slippage" before the system engages.
  18. Jan 6, 2015 at 9:53 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Smiley face eating popcorn
  19. Jan 7, 2015 at 9:29 AM
    CorporalKlinger
    CorporalKlinger Active Member
    Calgary, AB, Canada
    Red 07 TRD
    LED fog lamps 285/70r17 Duratrac 3" lift More to follow...
    I should have some info to add... My whole city is a skating rink atm. (Calgary, Alberta). I am on 3 month old duratracs, 285/70r17. Done some minor wheeling in it to get access to ice climbing, so driving on frozen rivers, open crossings, frozen mud, packed snow, half frozen gravel, and fresh snow. Overall I would say that the abs in our truck has too much authority, ie it can kick in too quickly in my mind. I'll do a little testing after work in my back alley (packed snow), and front Street (skating rink) to see what I get. I'll maybe even break out the go pro (if I can find it) at 60fps and let everyone analyze.
    Any specific stuff you guys want me to for and watch for? I'll also pull the abs fuse for a bit and see if I can do better than the system.
  20. Jan 7, 2015 at 9:37 AM
    watchdog
    watchdog Well-Known Member
    jim
    nanuet n.y.
    09 tacoma
    Rims and tires , exhaust , stereo , Bhlm ,Changed carpet to black from grey. toytec ultimate lift kit. Allpro front bumper and light bar. In process of blacking out interior. Otrattw switches, black vinyl armrest mod, clazzio leather seat covers with heaters, flowmaster dual exhaust, hornblasters train horns,
    subbed
