ABS issues on icy roads and tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fightnfire, Jan 6, 2015.
Have you experienced ABS issues on icy roads?
Poll closed Feb 5, 2015.
  1. Stock tire size - I have NOT experienced ABS issues on icy roads
    28.7%
  2. Stock tire size - I HAVE experienced ABS issues on icy roads
    35.7%
  3. Oversized tire - I have NOT experienced ABS issues on icy roads
    20.9%
  4. Oversized tire - I HAVE experienced ABS issues on icy roads
    14.8%
  1. Jan 10, 2015 at 2:15 AM
    #121
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    The attached report is 12+ yrs old, and contains data that is 20 yrs old. But gives solid evidence of the effect the right tires make in Winter Driving conditions. I came across it when debating switching from studded Winter tires to studless Winter tires in 2010. I thought some people in this thread might appreciate the data contained within. Personally, this is my fifth Winter running Blizzaks as my dedicated Winter tire on all my vehicles; I ran studded Winter tires for 8 Winters prior to that. I consider the investment in dedicated Winter and Summer tire sets "an ounce of prevention worth a pound of cure." Just my opinion FWIW.
  2. Jan 10, 2015 at 2:43 AM
    #122
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As the ABS system is only getting limited real time data, Basically only the wheel speed data. There is lots of fuzzy guesswork based on averages ( more so than fact actually ) involved in the ABS Fuzzy Logic Controller Programming.
    Read Here:
    http://www.ijser.org/researchpaper/fuzzy-logic-anti-lock-brake-system.pdf
    http://www.idosi.org/mejsr/mejsr20%2810%2914/19.pdf
    The ABS system is set-up to operate optimally using the factory equipment at factory ride heights wheels tires etc ... on and on. Once any of that is changed it has to impact the functionality of the logic programming.
    I am not inferring that modifying your truck is the cause 100% of what you guys are seeing. Just trying to inject some knowledge into the conversation.
  3. Jan 10, 2015 at 2:54 AM
    #123
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree.
  4. Jan 10, 2015 at 4:17 AM
    #124
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Too much? :notsure:
  5. Jan 10, 2015 at 4:22 AM
    #125
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    My most memorable issues occurred on packed snow downhill in a subdivision under 15 mph. Not ice.
    I was idling in gear downhill approaching a T intersection. Depressed clutch, depressed brake, sped up.
    My hypothesis is that while in gear I was getting traction by the small snow wedges in front of the tires but that the ABS cycling was not allowing them to form. It happened several times with stock tires but hasn't with MS2s.
  6. Jan 10, 2015 at 4:32 AM
    #126
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Aaaaannndddddd...
    /thread
  7. Jan 10, 2015 at 4:59 AM
    #127
    Jimmyh
    SC
    2012 Prerunner SR5
    Looks like me when I was much younger! [​IMG]
  8. Jan 10, 2015 at 5:47 AM
    #128
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Awesome! Here I didn't think I could like you more. :cool:
  9. Jan 10, 2015 at 6:52 AM
    #129
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    Aaaaannnddddddd...
    It happened. It was not a figment of my imagination.
    I would assume others have issues in certain situations and they shouldn't be dismissed.
    Ultimately, if someone is looking for permission to mod their truck on the Internet they probably shouldn't.
    If someone is looking for information on modding they are in the right place.
  10. Jan 10, 2015 at 7:43 AM
    #130
    CorporalKlinger
    CorporalKlinger Active Member
    Calgary, AB, Canada
    Red 07 TRD
    LED fog lamps 285/70r17 Duratrac 3" lift More to follow...
    Okay so when you put better tires on you had more traction? No way that's so weird!
    But seriously... When you hit the brake in this instance did abs activate? To me it sounds like one of those specific situations where abs may not help to stop, but will help you maintain control of the Truck.
  11. Jan 10, 2015 at 8:02 AM
    #131
    CorporalKlinger
    Calgary, AB, Canada
    Red 07 TRD
    You don't take winter tires off every time it snow. You have them on for the winter when it is likely to snow, and you leave them. No one swaps them every time.
    It's not that hard to stick tires in a corner of your garage, or hang them on a wall. And yah "huffing around mid tires" isn't how most people spend their life. But it's not going to become your life. If you're competent it might take you twenty minutes to change a set, plus a retorque in a couple days. Not that big a deal if you want to be safer on the roads.
    And there are winter tires that are rated for mud. Not bogging, but they do just fine in it. They are mandatory on a lot of highways in the Canadian rockies, it's simply too dangerous without them.
    And you talking about your brakes "failing" is bull. I've done a hell of a lot of winter driving. With all season tires, mud tires, winter tires, stuffed tires, and with tire chains on. I've been out if control before, when the lack of friction on a surface surprised me. Believe me, I know the feeling. But not once have I been in the ditch or hit another car or missed a corner because of it. I've pulled plenty if people out of ditches though. And every single time they were not driving for the conditions and their tires. If you have judged the roads correctly, then you should not have an issue. When abs kicks in it may seem to the uninitiated that brakes have "failed". The haven't. You simply only have that much traction. If you hit something in that instance, then you weren't driving according to the conditions, it's that simple.
    Don't try to blame Toyota for you not being able to drive in ice and snow. It's difficult. No shame there. But just admit it.
    Disclaimer: this whole post assume an abs system without a fault. If you believe that you have a genuine problem with a system not working correctly then go to a dealer immediately.
    archerm3 likes this.
  12. Jan 10, 2015 at 8:05 AM
    #132
    scocar
    scocar Patron of the Farts
    I haven't read a single word in this thread. I am just here to say that it is a good goddamn thing that the use of these images was performed by qualified and certified individuals, and that no one has to die. This time.
  13. Jan 10, 2015 at 8:19 AM
    #133
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    GENTLEMEN! You can't fight in here. This is the war room!
  14. Jan 10, 2015 at 8:26 AM
    #134
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    I just had to do it. :eek: Literally couldn't stop myself ... As soon as I read his post "The Jimmy Pic" was all I saw. There wasn't time for a proper request for usage. :D
  15. Jan 10, 2015 at 8:29 AM
    #135
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
  16. Jan 10, 2015 at 9:38 AM
    #136
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    If you have a problem with your ABS you need to slow down more and use the best rubber to give yourself and advantage. That's all we are saying.
    I've never said you don't have a problem or that Toyota shouldn't be working on it. Report your issues to the NHTSA so they go somewhere that might be able to exact some change. That's my advice.
  17. Jan 10, 2015 at 9:52 AM
    #137
    CorporalKlinger
    Calgary, AB, Canada
    Red 07 TRD
    I don't need to see the conditions to know that someone who ended up through an intersection or in a ditch was not driving appropriately. By definition they weren't, it's that simple.
    If your brakes FAIL then why the hell are yo u still driving the Truck?
  18. Jan 10, 2015 at 9:59 AM
    #138
    Fightnfire
    Fightnfire [OP] Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Great read, thanks!
  19. Jan 10, 2015 at 10:02 AM
    #139
    TacomaRobert
    TacomaRobert Well-Known Member
    Incredible. All this arguing over that.
    Here is another ABS thread has devolved into arguments over something that is ridiculously obvious.
    We should all stick to simpler stuff. Like, "My wheels are loose, what should I do?"
  20. Jan 10, 2015 at 10:10 AM
    #140
    TacomaRobert
    Hey everyone, there's a new thread about someone's first oil change. I think we would all be better off heading over there.
