ABS issues
Discussion in 'Technical Chat' started by Stillfly199, Mar 30, 2010.
  1. Mar 30, 2010 at 5:21 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    My ABS light came on yesterday, but the truck stopped fine and wasnt throwing a code on my scanguageII. Then today I drove to the gym, 10 miles one way, then came home. Got in my truck to go golfing and as I was driving down the driveway I noticed the sounds of the ABS kicking in while I was on the gas. Got onto the road and it did it while I was accelerating. I pushed on the brakes and it pulled right. So came back home and looked around and didnt notice anything out of the ordinary, like leaks or anything, and brake fluid was good. Went back into town and it made that noise when I first took off again but didnt anymore. Anyone run into this or have any ideas what to look at?
  2. Mar 30, 2010 at 7:20 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
  3. Mar 30, 2010 at 7:23 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    sounds like your ABS module is going bad. check under the hood and make sure all the hose connections are tight.
  4. Mar 30, 2010 at 7:27 PM
    rmb_crew
    Try bleeding the brakes. Maybe air got into the system and is throwing off the system.
  5. Mar 30, 2010 at 8:48 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Alright, I will check those. I checked it when it happened and it seemed good, but I will double check. Thanks for the response.
  6. Mar 30, 2010 at 10:27 PM
    Duck760
    Duck760 The Duck
    I have an 07 tacoma and had the abs light come on twice... both times i took it to the dealer and the sensors went bad... mine was under warrenty
  7. Mar 31, 2010 at 1:05 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    That is what I am fearing. We had one go bad in an old car and it was I think $1000, which will totally blow right now
  8. Mar 31, 2010 at 10:25 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Before you start replacing sensors.... clean them first. If there is metal debris on the sensor it will send the fault like it is bad.
  9. Mar 31, 2010 at 12:25 PM
    Duck760
    Duck760 The Duck
    yeah it was right at about 1k for the job
  10. Mar 31, 2010 at 2:44 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Where are the sensors?
  11. Mar 31, 2010 at 5:47 PM
    rmb_crew
  12. Mar 31, 2010 at 7:08 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
  13. Mar 31, 2010 at 7:10 PM
    rmb_crew
    lol nice. Good luck.
