ABS KICKING IN ON DRY PAVEMENT
Discussion in 'Technical Chat' started by 2012Tacoma, Apr 1, 2014.
  1. Apr 1, 2014 at 7:20 AM
    2012Tacoma
    2012Tacoma [OP] Active Member
    Canton Ohio
    2012 Toyota Tacoma DBL Cab 4x4 TRD Sport
    Interior: Brake Controller TRD Seat Covers Weather Tech Floor Mats Exterior- Goodyear Wrangler Dura-Trac's 275/65/18 Firestone Ride-Rite 5000lb air bags 50" CREE LED Roof Mounted Light Bar custom made no drill mounts.
    I have a 2012 tacoma and the abs kicks on when im driving on dry pavement.
    Does anyone know if the abs sensor reads off the Wheel hub or tone ring on cv axle shaft?
  2. Apr 1, 2014 at 7:28 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It will kick in, if you brake hard on dry pavement. It's designed to not let your wheels, to lock-up/skid ( wet, or dry)
  3. Apr 1, 2014 at 7:29 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^this.
  4. Apr 1, 2014 at 7:32 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    There was a recent recall on certain 2012 and 2013 Toyota vehicles which included some Tacoma's. They are of course VIN specific and this recall relates the the ABS system. It is a software update that is now available. You can check your VIN at the toyotacare website to see if your truck is included.
    I never had an issue with my ABS system but my truck was under the recall. I've had the software update completed at the dealership. I have noticed no change in the behavior of the truck, but I didn't sense any issue before the update.
    Just FYI - may or may not help you out.
    Check VIN here: http://www.toyota.com/owners/web/pages/resources/recalls?siteid=too_toyota_recall_vinlookup
    http://www.tacomaworld.com/forum/4-cylinder/315816-another-toyota-recall-february-14-2014-a.html
