ABS kicking in under normal turning conditions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sierrakiwi, May 22, 2021.
  1. May 22, 2021 at 1:47 PM
    Sierrakiwi
    Sierrakiwi [OP] Member
    Hey guys,
    my ABS kicks in on medium- sharp right hand turns only, definitely when it does not need too. If I take it slow through these turns I can hear almost a pump pressurize for a split second or a little whirring sounds for a second on the passenger side of engine bay? - not sure how else to explain the sound. There is no ABS light on the dash? Unsure what it could be, I was thinking maybe a wheel bearing or something?
    Thanks
  2. May 22, 2021 at 1:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  3. May 22, 2021 at 1:51 PM
    tcjacado
    tcjacado Well-Known Member
    Did you do any suspension work lately, new wheels and tires, lift, alignment?
    Most likely a wheel sensor is pulled to tight/stretched, nicked or frayed, or just could going out.
    Other wise the vsc needs to be recalibrate to 0. There are directions on how to do this in a thread here.
    Edit... see above post from Randy
    Sierrakiwi[OP] likes this.
  4. May 22, 2021 at 1:53 PM
    Sierrakiwi
    No I’ve been meaning to do lower control arms since the LBJs are torn, they don’t clunk or anything but I got given new control arms from a friend so figured I’d put them in soon. Thanks guys.
