ABS kicking on on Dry pavement
Discussion in '1st Gen. Tacomas (1995-2004)' started by cottonbroker, May 21, 2009.
  1. May 21, 2009 at 7:29 AM
    cottonbroker
    cottonbroker [OP] Member
    Indiana
    TRD extended cab
    My ABS light came on the other day after driving off road and a few times while trying to stop on dry pavement the abs started allowing the wheels to roll.
    What type of code reader will pick up the issue. If I could figure out where to focus my efforts that would be a huge help. I'll take the wheels off tonight and see if i can find the sensors and try to figure out how to clean them.
  2. May 21, 2009 at 7:43 AM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    clean your brakes out real good after off roading it should stop on its own.
  3. May 21, 2009 at 8:01 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    back brakes could be out of adjustment as well.
  4. May 21, 2009 at 3:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on the sensors........remove the one bolt holding them in and spray them good with electrical contact cleaner and put them back in. that way...you can eliminate the problems and figure out whats going on.
  5. May 21, 2009 at 9:52 PM
    efranck2
    efranck2 The Eternal E
    St. George Utah
    2004 Tacoma Limited Doublecab 4x4 impulse red
    Brute Force Intake, Flowmaster Exhaust, 3 Inch Lift, Bilstein shocks, HiD Lights, Security System, Gray wire mod,
    or you can just take the abs fuse out of the fuse box, that what i did, cause i normaly wheel in the sand and its kinda scary when your comeing up to a razorback and your not slowing down when your standing on the brake :p
