ABS light always on
Discussion in '1st Gen. Tacomas (1995-2004)' started by skaf402, Jul 31, 2017.
  1. Jul 31, 2017 at 3:56 PM
    skaf402
    skaf402 [OP] Well-Known Member
    Omaha Nebraska
    2000 trd Tacoma 105k
    5100 blistein, 33 Goodyear wrangler, snorkel,
    Alright...so long story short I've read a bunch of threads on this topic and I couldn't really get a answer that made sense to me...so bottom line. 1. My abs light is on 70% of the time in my truck, comes on very randomly 2. I understand what abs is but what does it mean when the abs light is on your dash?
    3. While we're on the brake topic...should I be bleeding/ changing my brake fluid much more reguraly with 33 12.5 15 tires?
    4. Is it worth the swap (and is it possible) to do a tundra swap on my 15 x 8 rims, or would getting drilled and slotted rotors be a good idea to prevent warping but not really gain stopping power.
    5. Last one, I wanted smaller tires to prevent a little ware on my suspension so how wide of a rim do I need to get 33 10.5 16? What's the best width for light trails, country roads, and city driving.
  2. Aug 1, 2017 at 12:56 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    ABS light on means there is a fault in the abs system. Without out knowing the code it's impossible to help you fix it.
    How often do you change brake fluid?
    Have to have 16's for tundra brakes. Some 16 still wont clear.
    10.5 tire 8 inch wide wheel
    skaf402[OP] likes this.
  3. Aug 1, 2017 at 4:31 AM
    skaf402
    Omaha Nebraska
    I bet the last time. Brake fluid was changed was probably atleast 10k ago with the previous owner.
  4. Aug 1, 2017 at 4:44 AM
    Americandad
    Americandad Active Member
    Scott
    Marquette MI
    99 Tacoma under construction
    Most likely a wheel speed sensor. Get the codes read.
  5. Aug 1, 2017 at 9:19 AM
    Glamisman
    Glamisman Well-Known Member
    this should help
  6. Aug 1, 2017 at 6:49 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Sorry for the hijack but what if the code reader says no abs found. Mine has been on since I got the truck 4 years ago
  7. Aug 1, 2017 at 7:00 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The blue tooth code readers usually wont do ABS. You'll have to have AutoZone read the code
  8. Aug 1, 2017 at 9:52 PM
    Glamisman
    I have 3 OBDII scanners, a Snap On Solus Pro V, one from UEI and a BlueDriver. My go to scanner is BlueDriver. It does ABS, how in depth, I do not know but probably good enough for basic scans. What I mean by "good enough" is that it will read the codes, it will not do anything else like cycle the pump for brake bleeding.
  9. Aug 1, 2017 at 9:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    My goto for abs is Toyota Techstream on my laptop.
    digitalferg likes this.
  10. Aug 1, 2017 at 9:59 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I can look it up tomorrow but i know you can get the lights to blink for a code with a paper clip.
  11. Aug 1, 2017 at 11:17 PM
    Trapperr
    Reno, NV
    I got the Bosch scanner that the oriellys up the street from me uses. Iy read codes on the subaru and the yukon but can't in the tacoma. I'll try again tomorrow
