ABS light and traction control on after lift
Discussion in 'Suspension' started by sierra141, Jun 21, 2009.
  1. Jun 21, 2009 at 6:14 PM
    sierra141
    sierra141 [OP] Well-Known Member
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    Waz up everyone I just finished installing my toytec coilovers and everything went well except for my ABS light and traction control light came on I dint disconnect any electrical wires or brake lines for that manner does anyone know how to turn them off I tried already with m y OBD II reader but no luck it dint show that they are on with the OBD
    By the way my truck is a 09. Any help would be greatly appreciated.
  2. Jun 22, 2009 at 7:50 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
  3. Jun 22, 2009 at 8:21 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Hey mine did this too. The dealer did my TSB and i started getting them. It is intermittent and only seems to be coming on when it gets really got out. The truck is at the dealer right now getting looked at. I will post more when i hear something.
  4. Jun 22, 2009 at 9:56 AM
    sierra141
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    thanks guys!
  5. Jun 22, 2009 at 3:18 PM
    rmb_crew
    so got back from the dealership and they told me that when i spliced into the wiring for my fog lights mod that that same wire goes to the abs system and that is whats causing the problem. I didnt really believe them so i pulled it all apart and put it all back together and will see what happens. Thats all i can tell you though. They had a whole list of codes it threw when it happened so.
  6. Jun 23, 2009 at 3:47 PM
    rmb_crew
    well after removing everything and putting it back to normal, it is still messing up so back to the dealer for them to look at it again. Any luck with yours?
  7. Jun 23, 2009 at 4:40 PM
    sierra141
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    I went with my friend at toyota to get an alignment and he check the system with their scaner. Apperently when I installed my coil over on the passenger side I pulled in the wire that controls those two systems I guess when I released the control arm it put tension and probably inside the harness of the wires must of tore up. He will try to get it covered under warranty.
  8. Jun 23, 2009 at 4:59 PM
    rmb_crew
    is your light on constantly or is it just every now and than?
  9. Jun 24, 2009 at 11:07 AM
    sierra141
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    Its always on both abs and the traction control one
  10. Jun 24, 2009 at 2:35 PM
    rmb_crew
    Huh mine is intermittant and it seems to be triggered by heat so it's going to the dealer tomorrow as soon as the lights trip on.
  11. Oct 14, 2011 at 6:26 PM
    asiantaco
    asiantaco Well-Known Member
    I have the same problem. How did you fix this?
  12. Oct 15, 2011 at 1:05 PM
    asiantaco
    Everything looks fine.
  13. Nov 16, 2013 at 11:22 PM
    SWCCBEE
    SWCCBEE So Cal Edition
    Greg
    Santa Rita, GU
    2010 PreRunner, SR5, TRD Sport
    WeatherTech floor liners, In process of Debadge, Leveling kit, Tires, Limo tint, Custom TRD SPORT Decal, "ImMrYo" Rear view lifting bar, Ultra gauge, relocated horn.
    Ok. I had the same problem after I put my led bar on. I moved a few wires and it went awsy. Will post pics later.
  14. Nov 16, 2013 at 11:38 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This guy has your answer most likely but alas, he's banned to a world of silence..
    It's quite possible you damaged one of the sensors/ sensor cables
  15. Nov 17, 2013 at 12:27 AM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Stretched wire
  16. Nov 17, 2013 at 12:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Bingo.... happened to me, just a little cable stretch & bye bye sensors, not cheap to replace either..
  17. Nov 17, 2013 at 1:33 AM
    SWCCBEE
    Greg
    Santa Rita, GU
    Sorry I'm at work and we cant have our phones w/us. The two sets I moved were both on the drivers side by the battery. A black ground and a pair of whites going into one connector ground.
