ABS light came on after leaving shop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cloydworld, May 11, 2020.
  1. May 11, 2020 at 7:12 PM
    Cloydworld
    Cloydworld [OP] New Member
    2006 Trd off road 4x4
    Took my 06 Trd double cab to a customs shop for a left front hub replacement and while it was there I wanted a 2 inch lift and level, new steering rack and upper and lower control arms. They called and said the front left wheel speed sensor was rusted and I said just go ahead and replace it no problem. Got the truck back and everything was running way better than before they even did a free alignment. About a week later my ABS light came on. Ran for codes and I got 32 and 41. Not sure if they messed with something but I look at the sensors and they all looked fine, all wires looked fine too from the sensors. Curious as to what my next step should be?
  2. May 11, 2020 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    It's an issue that needs to be addressed by the shop.
    It's possible they pressed the bearing incorrectly causing the abs tone ring damaged. But either way it's related to what they did.
    Code 32 is left front. 41 is low voltage, very common code, should check your battery as well.
    Cloydworld[OP] likes this.
  3. May 11, 2020 at 7:22 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
  4. May 11, 2020 at 7:33 PM
    Cloydworld
    First time I’m hearing about recalibrating vsc, thanks for the insight and I was thinking about inspecting for gunk by taking off the sensor if anything else doesn’t work. Would hate to take it back to the shop because they were a little less professional than expected
    ryfox0276 likes this.
  5. May 11, 2020 at 8:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    An improperly pressed bearing could allow the tone ring to contact the sensor wearing it and possibly causing a voltage issue due to a partial short circuit.
