ABS light coming on, code 34.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BKinzey, Dec 10, 2016.
  1. Dec 10, 2016 at 1:39 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    In the last few days the light comes on after driving about 20 miles, today it came on at about 5. My OBD reader shows no codes.
    I just got the 327 reader about a week ago, using Fusion on an Amazon Fire 8, would that have anything to do with it?
  2. Dec 10, 2016 at 1:54 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Trying reading the codes through the dash, that will tell you for sure.
  3. Dec 10, 2016 at 2:02 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
  4. Dec 11, 2016 at 4:01 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Thanks for the repiles, good to hear the code reader I bought doesn't read the codes I need it to. :(
    The Amazon Fire isn't working out too well either, it's Android, but it's not a "real" Android o_O and has very limited Apps. :annoyed:
    The SST Jumper, is that a common item one can buy or does one make it?
  5. Dec 11, 2016 at 4:03 PM
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    My abs comes on here and there as well. Usually on at cold start ups in the mornings. When I want to take it to the dealership, it doesn't turn on.
  6. Dec 11, 2016 at 7:12 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Bought it used with 25,000 miles on it. I've put another 10,000 on and the ABS started coming on less than 100 miles ago. Might just take it to the dealer, I'd like an idea of what's going on though.
  7. Dec 12, 2016 at 8:24 AM
    TacoTSS
    TacoTSS Active Member
    Jimmy
    Mississippi
    2015 MGM TSS
    Tint Blacked out All badges Replaced oem grill with mesh and black out chrome surrounding it Tanneou cover Chest Tool box Mississippi sportsman seat covers Weather tech mats Avs window visors Avs bug deflector 3" rough country leveling kit Lund led bull bar
    mine did that a while back I took it to the dealership since it was still under warranty and they told me it was a dirty sensor they cleaned it and it hasn't done it since sorry I cant remember for the life of me which one it was now I know it wasn't the actual abs sensor but another one
  8. Dec 13, 2016 at 9:46 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Sorry for the delayed reply. A fine bare wire paper clip bent open works great, just don't use one too thick or the pins in your OBD11 connector can be damaged.
  9. Dec 13, 2016 at 10:17 AM
    rberumen2
    Ralph
    California
    mine went on again on the way to the gym at 5am. then leaving the gym it didn't turn on.
  10. Dec 18, 2016 at 10:17 AM
    Yoda2009
    Yoda2009 Yoda2009
    Lbi
    2009 tocoma sr5 base
    Plastic dip badges. Upgraded head unit, husky floor liners, BFG ko2 tires.
    Mine did that. Then stayed on. Took it to dealership they were confused cause no codes. They replaced the scensor then tried to blame it on my led stock tail lights! Haha and trailer aftermarket wiring harness. Suppositly they put a resistor in somewhere and it worked. Either way no abs light since!
  11. Dec 18, 2016 at 7:48 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Ok, got around to checking the DTC code with the SST.
    It's 34. Searching the forum I find:
    34 - Left Rear Wheel Speed Sensor Signal Malfunction
    Now I gotta find that and check the connection.
  12. Dec 27, 2016 at 9:07 AM
    BKinzey
    Beauford
    Hollywierd, CA
    Had a chance to get under there and check the connection, nothing obvious. Unplugged it, looks in good shape and clean so I plugged it back in. I've gone on a trip and drove about 500 miles and it didn't come on until I parked it and it dropped below freezing. Came on right when I started the truck. Now it's gone off again.
    When I get back I'll look into it further.
  13. Dec 27, 2016 at 9:22 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Wheel speed sensors usually go bad for reason, that reason usually being a bad bearing. Check that when you get time. Seems odd for a rear bearing to go bad so soon.
