ABS Light is Driving me nuts.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oh_Six_Taco_4x4, Nov 17, 2009.
  1. Nov 17, 2009 at 8:21 AM
    Oh_Six_Taco_4x4
    Oh_Six_Taco_4x4 [OP] Professional High Fiver
    Orange Park, FL
    TRD Sport 4x4
    OEM skid plate. 3" Toytec lift with AAL. Trail Gear Rock Sliders Rechargable Maglite
    I recently had my driver side wheel bearing replaced by a friend of mine. Now, the ABS light is on. Does anybody have any idea what is going on? Can it be turned off? The ABS seems to be working just fine. HELP! :confused:
  2. Nov 17, 2009 at 6:50 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    i have the same problem, I got it after doing the bilstein strut swap.
  3. Nov 17, 2009 at 6:50 PM
    kcbmx
    Marco
    2tr-fe 4wd
    somebody help!
  4. Nov 17, 2009 at 6:55 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Black electrical tape over the light, problem solved! :D
    Just kidding. I'm sure someone will have a legitimate fix.
  5. Nov 17, 2009 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    may need to recheck where the sensor is plugged in. take the bolt out......pull the sensor and clean it withan electronics spray cleaner...then reinstall. have had a small piece of dirt/dust on the sensor.
  6. Nov 17, 2009 at 7:26 PM
    Porsche917k
    Porsche917k Active Member
    +1 I did 5100's this weekend and now my ABS light is on. The only thing I can think of is that the ABS harness may have gotten pulled during the install and damaged a wire. Can anyone tell me if I pull the code, will it tell me which side has the fault?
  7. Nov 19, 2009 at 8:15 PM
    kcbmx
    Marco
    2tr-fe 4wd
    ill work on mine tomorrow.
  8. Nov 22, 2009 at 7:17 AM
    Oh_Six_Taco_4x4
    Orange Park, FL
    TRD Sport 4x4
    i'm gonna try the cleaning method first. If that fails, I'm going with the electrical tape over light approach.
  9. Nov 22, 2009 at 7:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes it will
  10. Dec 5, 2009 at 8:22 PM
    kcbmx
    Marco
    2tr-fe 4wd
  11. Dec 8, 2009 at 11:28 PM
    kcbmx
    Marco
    2tr-fe 4wd
  12. Dec 8, 2009 at 11:31 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i had an issue with the abs light the other day. The wire actually broke. Take the plug lose at the wheel bearing and the plug on the other side of the wire ( on the inner fender) lose and check continuity...I had an open wire.
