ABS Light Issues - Code C1421 - Anyone have diagnostic info?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maurzog, Aug 14, 2023.
  1. Aug 14, 2023 at 9:04 AM
    maurzog
    maurzog [OP] Well-Known Member
    Code says - Open or Short in Master Cylinder
    Looking for some help or if anyone has access to diagnostics for this code, not much information when googling.
    Repair shop says I need to replace the entire Brake Booster Pump Assembly on my 16 TRD OR.
    $1800 for the part and another $900 for install and Techstream calibration.
  2. Aug 14, 2023 at 9:07 AM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    C1421 Open or Short in Master Cylinder Pressure Sensor Any of the following is detected:
    • When voltage at terminal +BS is 9.5 V or higher, power supply voltage of master cylinder pressure sensor is continuously low for 1 second or more.
    • When master cylinder pressure sensor power supply voltage has risen, master cylinder pressure sensor has overheated or overcurrent of master cylinder pressure sensor continues for 0.1 seconds or more.
    • When +BS terminal voltage is 9.5 to 17.4 V, there is no communication with master cylinder pressure sensor continuously for 0.1 seconds or more.
    Brake actuator assembly (Master cylinder pressure sensor)
  3. Aug 14, 2023 at 9:34 AM
    maurzog
    Thanks. I was hoping I had a ground short somewhere but appears it is internal in the pressure sensor.
