ABS light, no ABS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 30, 2011.
  1. Jun 30, 2011 at 12:09 PM
    beachbumberry
    beachbumberry [OP] Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
    Brakes work fine, i've been driving with it like that for 6 months, but the inspection is coming due so it's time to make it go out. Cleaned the sensors (were a bit dirty) but not getting any change. The light came on during an ice storm, but i havn't found anything actually damaged... Ideas?
  2. Jun 30, 2011 at 12:25 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I have an idea but I am not sure this is what you are dealing with. I just reently installed the OME Heavy Load front springs due to the addition of the ARB bumper it was sagging a tad. When I took off the passenger side upper control arm castle nut, the spindle just dropped really fast and I was not fully prepared and did not catch it so it stretched out the ABS sensor wires. When it did this you could not see the line broken anywhere, and the external sheath was all there, but you could tell there was a section that looked narrower than the rest. When I got the truck all back together the ABS light was looking at me, I figured well I guess I did do something to it when it dropped fast. I ended up pulling back the external black rubber sheath to discover the two wires inside had been pulled until they snapped the wires themselves. It had the wire sheathing looking like a pigtail it stretched so bad. That being said after figuring it out it was very easy to repair, I got some fresh ends on the wires and then tapped them all back together for the resulting no ABS light. So maybe you were not doing something like that but maybe something popped up and hit the line or something, its a start at least. Good Luck!
  3. Jun 30, 2011 at 12:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Could be the clock spring. You'll probably have to hit then dealership up for diagnosis if it isn't anything obvious.
  4. Jun 30, 2011 at 5:22 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    A clockspring would throw an air bag code. Get your codes read it wil tell you where to start looking.
    Probably a sensor problem.
  5. Jul 1, 2011 at 1:53 AM
    beachbumberry
    andrew
    fl now, tx native
    i also have (and have had for about 7 months longer than the ABS light) an airbag light. what is a clock spring? never heard of it before. Called all the dealerships and local shops around, but noone has a diagnostics machine that will work with US-spec toyotas... down side to being in England. I have a friend with a cable and computer programs that MAY be able to read it, but he cant until monday or tuesday, so i will be cleaning the sensors and tracing the wiring in the mean time.
  6. Jul 1, 2011 at 2:55 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Clock Sping - a sliding electrical contact within in the sterring wheel.
    You need an OBDII scanner.
  7. Jul 1, 2011 at 3:16 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    For the abs light, could be a cracked or damaged tone wheel, bad abs sensor, brake switch above pedal, etc... Can basically be any of a bunch of things. For the clock spring, think of it this way, if the steering wheel had wiring to the airbag and horn, eventually the wires would break from twisting back and forth while turning the wheel back and forth all the time. The clock spring makes constant electrical contact for your horn and steering wheel mounted airbag.
  8. Jul 1, 2011 at 4:50 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    You can remove the airbag and test resistance across the clockspring. Wait 15 min after disconnecting the battery before removing the airbag. Don't let anything touch the airbag's connector after removing.
    I think the TTORA guys have a schematic for our trucks.
  9. Jul 1, 2011 at 6:55 AM
    beachbumberry
    andrew
    fl now, tx native
    i didnt know what that spring was called but makes sense now. gonna start tinkering today after work, hopefully i'll get somewhere with it. thanks for the pointers, i'll update as i make progress for more troubleshooting ideas
  10. Mar 2, 2013 at 6:48 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    If you pulled the ABS fuse and drove like that it sets two codes in the system one will go away when fuse is put back the other you need a scan tool to erase.
