ABS light on after audio install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rocky Truck, Jan 15, 2008.
  1. Jan 15, 2008 at 8:04 PM
    Rocky Truck
    Rocky Truck [OP] Proud Confederate
    07 4X4 6-Speed TRD Offroad Package
    Had a local audio shop intall my previous cars (01 honda accord) sound system into my new Tacoma. They do great work ...however... After getting her back, the ABS light is on. All that was installed was an Alpine head unit, some subs, and a sub amp. Any ideas on how this could have happened. The shop said send them the bill from the dealer. The car has 178 miles on it!!!
    -Chris
  2. Jan 15, 2008 at 8:18 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    sounds like they may have wired it in wrong. could be as simple as that
  3. Jan 15, 2008 at 8:20 PM
    Rocky Truck
    It just doesnt seem right... maybe they left a connector unplugged when they turned the car on? That would set a hard ABS code...
    But this guy has been in the business for 20 years...don't see why it would be botched...maybe just needs to be reset? Is there any connector behind the audio unit that ties into ABS??
  4. Jan 15, 2008 at 9:20 PM
    lineberw
    lineberw Well-Known Member
    Summerville, SC
    TRD 4x4
    Hey it is possible they wired it without disconnecting the battery. We all get ancy and are suppose to disconnect the negative terminal on the battery. So the could of popped a fuse when wiring you HU.
  5. Jan 16, 2008 at 4:24 AM
    colttsi
    colttsi Well-Known Member
    If they said to send them the bill from the dealer, in my opinion, it means that they made a mistake and know it very well, they just won't tell you directly. The fact that they accept to pay for it means that they are professionnals and have a good reputation. Send them the bill. There aren't too many shops like that.
  6. Jan 16, 2008 at 2:03 PM
    Rocky Truck
    UPDATE:
    The amp was installed underneath the driver seat, and upon sliding the seat back...the corner of the amp hit the yaw sensor rendering it inoperable. Shop is paying for a new yaw sensor and install....
    -Chris
  7. Jan 16, 2008 at 2:16 PM
    jace05
    jace05 New Member
    orlando fl.
    06 prerunner trd
    The Same Thing Happen To Me . Just Disconnect The Battery And It Will Go Off.
  8. Jan 16, 2008 at 2:20 PM
    Rocky Truck
    Negative, the sensor seems to have been damaged internally (shock or bump?). Tried hard-clearing the code with OB2 scanner and it stays on solid...so they ordered a sensor for me...
    -Chris
  9. Feb 14, 2009 at 8:31 PM
    this_is_nascar
    this_is_nascar Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    What's the "yaw" sensor?
  10. Mar 23, 2009 at 4:59 PM
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Can someone explain to me what this sensor is under the driver's seat and what it has to do with ABS? Is there a similar sensor under the passenger's seat? I'm asking because I'm having a similar problem with a CB amp installation.
  11. May 11, 2009 at 1:30 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    oh snap I think I'm having the same problem.. How much did it cost?
  12. May 11, 2009 at 3:31 PM
    bk1
    bk1 Well-Known Member
    Lower Mainland, BC
    08 Tacoma TRD Sport
    ProComp Stage 2 6" lift, AAL, Heated Mirrors, DVD/NAV, Amp & Subs, Fog Light Mod, Rear Diff breather. WeatherTech Mats, Soft Tonneau Cover, 33" TrXus M/T, M8000 Winch & Bumper, CB, Rock/suspension Lighting and a whole lot more Soon to come rear Locker and more....
    YAW or Critical Velicity Skid/Scuff(same thing) is caused by the rear tires tracking outside the front tires - Normally related to vehicle collisions. you'll see it when the tires are still rotating but instead of moving in a straight line they are moving sideways(side slipping). its kindalike fishtailing or power sliding.
    I'm assuming the sensor can read G force/Body roll for the ABS/VSC and Airbag and allows the vehicle to help regain control to you dont roll it.. or worse, crash it.
