ABS light on after LED 3rd brake light install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by celticguy6405, Aug 8, 2016.
  1. Aug 8, 2016 at 5:40 PM
    celticguy6405
    celticguy6405 [OP] Member
    Bryan
    07 Tacoma
    Hey guys, my first post. I recently (like 10 minutes ago) installed an LED 3rd brake light on my 07 taco and after the first start-up my ABS light came on... Don't think the 2 should be related. It's never been on in the year Ive owned it. I took it for a ride with some aggressive braking and nothing was triggered, all seemed normal and after cycling the key a few times the light shut off. I did pump the brakes right after the install while the truck was off but accessory on, to test the light's function. Just seeing if this sounds normal. I have a pretty good mechanical knowledge and know the ABS system shouldnt have anything to do with it but it kind of gave me a "the fuck??" moment. There's always great input on here so let me know if there's something I'm missing here. Thanks
  2. Aug 8, 2016 at 5:46 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    How many times did you pump the brakes? Multiple times will discharge the ABS accumulator. I don't know the exact number though
  3. Aug 8, 2016 at 5:50 PM
    celticguy6405
    Bryan
    07 Tacoma
    It was probably a good 10-15 times. I was trying to see the reflection but ended up having my little boy stand in the bed so I could see it off him. The pedal was stiff by then.
  4. Aug 8, 2016 at 5:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Put the old light back in and see if that light goes away. If it does, then the system thinks you have a light burn out. This is why we need resistors to fool the electrical system ECU.
    Please report back.
  5. Aug 8, 2016 at 5:51 PM
    celticguy6405
    Bryan
    07 Tacoma
    It shut off after a few key cycles
  6. Aug 8, 2016 at 5:51 PM
    Aussiek2000
    2016 Offroad AC
    His ABS went off after he drove it I think
    celticguy6405[OP] likes this.
  7. Aug 8, 2016 at 5:53 PM
    Aussiek2000
    2016 Offroad AC
    I'd say you just pumped the pedal to many times. Drive it a couple days and see if it comes back on
  8. Aug 8, 2016 at 5:55 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Disconnect the battery over night.Ecu could of gotten scared by the bright lites!let us know what happens.oh yeah welcome....
  9. Aug 8, 2016 at 5:55 PM
    celticguy6405
    Bryan
    07 Tacoma
    Will do, I still have my old one obviously and had read about others having issues after installing the LEDs so immediately I thought Id be one too. Ill let you guys know if it returns. Thanks for the quick responses!
  10. Aug 8, 2016 at 5:57 PM
    celticguy6405
    Bryan
    07 Tacoma
    Thanks Hot Tacoma Blown! I love being a part of this group!
  11. Aug 9, 2016 at 7:22 AM
    celticguy6405
    Bryan
    07 Tacoma
    Well, started my day with abs light coming back on. I pulled the code and it's c1249 which is "open in stop light switch circuit". It is off when I start the truck but doesnt come back on until I use the turn signals (both sides). I hate having lights on my dash, not sure if I should just deal with it or put the stock one back in.
  12. Aug 9, 2016 at 5:17 PM
    celticguy6405
    Bryan
    07 Tacoma
    I was just going to deal with the light until I realized my cruise control was also affected by this so for the hell of it I threw in a resistor and BOOM, problem solved!
    Tonylr likes this.
  13. Feb 20, 2022 at 2:43 PM
    Tonylr
    Tonylr New Member
    2006 Tacoma Prerunner 4x2
    Hello, I hope you are well. I have the same problem in a 2006 Tacoma. A few days ago I installed the 3rd brake light in leds from Amazon and now when I put the signals to make a turn the abs light throws me and it scanned c1249 "open circuit in stop light switch circuit" Could you tell how it was that you put a resistor on it and solved the problem?
  14. Feb 20, 2022 at 3:09 PM
    celticguy6405
    Bryan
    07 Tacoma
    I bought an LED load resistor from oreilly auto parts. I installed one end of the resistor onto the positive wire using the wire connectors that came with the resistors. Then I attached the other end of it to the ground wire and mounted the resistor to the inside behind where the third brake light goes. It's a pretty easy process. Only thing to keep in mind is that resistors get hot so make sure it's not touching anything you don't want it to. Good luck
    Tonylr likes this.
  15. Feb 20, 2022 at 4:20 PM
    Tonylr
    Tonylr New Member
    Thanks for your quick response!! I'll do it as soon as I can, thanks again :thumbsup:
  16. Feb 21, 2022 at 4:27 PM
    Tonylr
    Tonylr New Member
    Did you use a 6 ohm 50w resistor? They are the most common but I have seen them with other specifications.
