ABS light on after lift installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nastyblowpop, Apr 7, 2010.
  1. Apr 7, 2010 at 11:06 AM
    nastyblowpop
    nastyblowpop [OP] Well-Known Member
    Long Beach, CA
    08 DC 4x4 rugged trail
    Yesterday I installed the ome 3" lift and got new tires, bfg at ko 285/75/r16 and after putting about 50miles or a little less on them my ABS light came on...I'm completely lost and have no idea why its on. Has anyone else had this problem?
  2. Apr 7, 2010 at 11:12 AM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    I had the same issue after my 3" lift and it turned out that the wire to the sensor was stretched. I still don't know if it was stretched when the lift was installed or coincidentially hooked by something while driving. Check your wires.
  3. Apr 7, 2010 at 11:24 AM
    nastyblowpop
    Long Beach, CA
    Ok that makes sense..how would one go about lengthening the wire?
  4. May 2, 2010 at 4:01 PM
    joshua32
    joshua32 Well-Known Member
    Joshua
    Tyler, TX
    06 Prerunner SR5
    Any insight to this issue? My light came on today after installing some Upper Control Arms. I think one of the wires might have gotten stretched but it looks fine. How can I fix this?
  5. May 2, 2010 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Replace the sensor.
  6. May 3, 2010 at 5:38 AM
    joshua32
    Joshua
    Tyler, TX
    06 Prerunner SR5
    I searched some more and I am going to take off the harness and check for continuity, then if that is ok, I will take off the sensor and clean it with electrical parts cleaner. If still no luck, I will have to buy a new sensor.
    NOW.......any idea where you can get a replacement without the $150.00 price tag?
    Thanks for the help!!!
  7. May 3, 2010 at 4:08 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Not sure about on the Tacoma's, but on an air braked truck, an abs sensor that is working should have resistance, not continuity.
    I'm not sure what the sensor resistance is supposed to be on the Taco's, for that you may have to do a little leg work.
  8. May 3, 2010 at 5:57 PM
    joshua32
    Joshua
    Tyler, TX
    06 Prerunner SR5
    I was going to check the continuity on the harness that could have been stretched to the point where it broke one of the wires. Then I will remove and clean the sensor...and we will see.
  9. Jun 7, 2010 at 1:40 PM
    Loiman20
    Loiman20 Well-Known Member
    utah
    double cab long bed
    BFG All Terrains 265/75/16 bull bar guard nerf bars 2 inch leveling kit grillcraft sport grill "toyota" emblem
    Same here installed billies at 2.5 and the light is now on
  10. Jun 8, 2010 at 8:41 AM
    nastyblowpop
    Long Beach, CA
    Welll I have tried everything and nothing seems to make the damn light turn off. So I'm breaking down and taking it to stealership tomorrow and see what they say. I have the certified platinum warranty so hopefully it covers it. Ill let you know what they say.
  11. Jun 8, 2010 at 9:36 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Please do, I'm intrested to see what they say since I'm looking into the 3 OME as well, thanks in advance!!
