ABS light on after Sensor and harness replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MorganJD, Mar 31, 2022.
  1. Mar 31, 2022 at 1:39 PM
    MorganJD
    MorganJD [OP] New Member
    Hey all, Recently I had my ABs, Brake, traction control and cruise control lights come on. Had a dealer diagnosed it and they said it was the front right wheel speed sensor. I got a new sensor and a new harness and put them both in today. However all the lights remain on. I've tried using this https://www.tacomaworld.com/threads...ibrate-your-vsc-computer-the-easy-way.467485/ to reset and it went away until I put it in gear everything came back on. After drive a couple blocks the lights flashed, turned off momentarily and then back on.
    I checked the new harness with a multimeter and was getting around 10V
    Update: had another scan done. now saying its the rear sensor is bad along with a few other codes (codes C1203, C1336, C1403) It seems unlikely to me that both the front and read sensors would go out at the same time.
    Anyone happen to run into anything similar? I'll replace the rear sensor if nessesary but id rather not spend another 200+ on a sensor if I dont need to.
    2016 Tacoma SR5.
    Thanks!
