ABS light ON, comp reads "debris in sensor"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808Renato, Aug 30, 2012.
  1. Aug 30, 2012 at 12:05 AM
    808Renato
    808Renato [OP] Well-Known Member
    Renato Medeiros
    Kauai
    16 MGM DC 4x4 6spd Manual
    ALOHA TW Friends,
    ABS light ON, comp reads "debris in sensor"...
    first time the light came on (2months ago), I cleaned the sensor and removed all the small debris as a result the light went off and everything seemed fined.
    This time around the light came back on again (5days ago) so I attempted to clean it out and the light went off for a few seconds and went back on again. Also I noticed that there were a lot of small dirt debris (twice as bad as first time) and even tiny shaved metal particles.
    Any suggestions? Maybe the seal on the sensor went bad?:notsure: Advices will be greatly appreciated!:cheers:
    MAHALO,
    Renato
  2. Aug 30, 2012 at 6:22 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not sure which sensor it is but it looks like seal is gone. If those are front sensors then most likely seal between CV and knuckle / spindle needs to be replaced. Keep in mind that if wheel bearing is bad it will make cv chew through that seal.
  3. Aug 30, 2012 at 9:14 PM
    808Renato
    Renato Medeiros
    Kauai
  4. Aug 31, 2012 at 1:15 AM
    808Renato
    Renato Medeiros
    Kauai
    its the driver side ABS sensor
  5. Aug 31, 2012 at 7:45 AM
    BlueT
    NorthEast
    How many miles?
  6. Aug 31, 2012 at 10:06 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    It is not unusual to find small, fine, metal shavings on these sensors, as they are a permanent magnet type sensor. I have found these shavings on every model I have ever done ABS work on.
    That being said, could you specify the actual code number? I will happily look it up and see if I can make any suggestions.
  7. Aug 31, 2012 at 12:49 PM
    808Renato
    Renato Medeiros
    Kauai
    92K
  8. Sep 9, 2012 at 11:26 PM
    808Renato
    Renato Medeiros
    Kauai
    Wheel bearing was the issue!! Thanks for ur help guys! Aloha
