ABS light on & off, brakes pulling to the left.
Discussion in '1st Gen. Tacomas (1995-2004)' started by yoTaco98, Jul 10, 2011.
  1. Jul 10, 2011 at 10:34 AM
    yoTaco98
    yoTaco98 [OP] Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    Guys I need a little help troubleshooting my ABS warning light. I've tried 2 diagnositics and niether of them gives the error.
    The ABS light on my truck constantly comes on and off.
    My front left wheel bearing was really bad, so I figured that may be screwing with the sensor, so I relpaced them. No fix, still on and off.
    It seems that the previous owner broke the front left sensor cable, right where it connects to the steering knuckle. The connection was pretty crappy, so I undid his splice and properly spliced it back together using solder, wrapped the lines and secured them correctly to the brackets on the steering knuckle. Still on and off.
    Today I noticed that when I brake semi-hard the truck pulls to the left. Could this have something to do with the ABS light?
    What could be causing the brakes to pull to the left?
    The ABS light will normally turn off when I start up, and can remain off the whole drive or turn back on as soon as I pull out of the drive way.
    Could a bad caliper make the truck pull, and this be the cause of the ABS?
    Thanks in advance for your help?
  2. Jul 10, 2011 at 11:30 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    A stickling caliper can make it pull. Air in the brake line can also make it pull. I dont know anything about ABS, but Im wondering if ABS not working one that one wheel could cause the pulling. Maybe someone else will know.
  3. Jul 10, 2011 at 11:34 AM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    +1....I would consider the calipers first a foremost. A bleed of the system after that and then see what she's doing.
  4. Jul 10, 2011 at 1:09 PM
    yoTaco98
    Yo
    VA
    I had the brake system flushed about a month ago. Is it possible they messed up on the flush and there is air in the brake line?
  5. Jul 10, 2011 at 4:31 PM
    bicklebok
    Ronnie
    Montgomery, AL
    Could be. It's not hard to bleed. I would definitely give it a try first.
  6. Jul 10, 2011 at 8:26 PM
    yoTaco98
    Yo
    VA
    I think I'm going to have the place that did my flush do it.
    Espcially since the brake fluid looks black again. I figure they didn't get everything out if the fluid they put in got dark again within a week.
