ABS light on, rear brakes locked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SKMP9, Jan 5, 2012.
  1. Jan 5, 2012 at 7:35 AM
    SKMP9
    SKMP9 [OP] Member
    NE Ohio
    05 Prerunner V-6
    Quick question. Leaving for work this morning, start up '05 Doublecab Prerunner, ABS light comes on. Tried to back out of drive, and can hear tires chirping. Pull back in, same thing in drive. The rears will lock, then release, lock, and release. I'm not too familiar with the wheel sensors, but from the symptoms, I'm assuming this might be the case ? I had new calipers and rotors put on the front last year in August, and they just adjusted the rears. The shoes looked almost new. Has anyone else had this happen, and what was the fix ???
  2. Jan 5, 2012 at 7:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Something could be something broken in the drum itself, or they could be frozen. I had the drums freeze up on me in an older truck.
  3. Jan 5, 2012 at 7:48 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    might be silly but diff locks off?
  4. Jan 5, 2012 at 10:48 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I'd remove the ABS relay and try it again. This will help determine if the issue is with the brakes or the ABS system
  5. Jan 5, 2012 at 3:35 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Unplug the connectors and clean the terminals. Maybe a little corrosion is causing bad connection :notsure:
  6. Jan 5, 2012 at 5:27 PM
    SKMP9
    SKMP9 [OP] Member
    NE Ohio
    05 Prerunner V-6
    Bfoster is the winner !!! In 8 years of owning my Taco, I have NEVER EVER used the diff lock. Somehow, when my 16 yr. old son pulled it in the driveway last night, he must have pushed it, instead of the fog light switch, which is next to it. So, all is good in the world again ! Thanks for the replies !
  7. Jan 5, 2012 at 7:31 PM
    Bfoster133
    Blake
    howd you pop em out?
  8. Jan 5, 2012 at 11:32 PM
    Bfoster133
    Blake
    so easy to pop out no clips or nothing? and pop out towards the driver and out of the dash?
  9. Jan 5, 2012 at 11:56 PM
    Bfoster133
    Blake
    :anonymous:
  10. Jan 6, 2012 at 6:00 AM
    Pugga
    Massachusetts
    The top left blank is where my fog light switch is from the factory so you might not have to extend the wires. I've got 3 light switches across the top now with my additions (and no switches on the bottom :().
