Abs light on while in 4 low
Discussion in 'Technical Chat' started by Bmb619tacoma, Nov 25, 2013.
  1. Nov 25, 2013 at 7:46 PM
    Bmb619tacoma
    Bmb619tacoma [OP] Member
    Brennan
    San Diego
    2004 tacoma 4x4
    Donahue racing 3 inch lift wheels tires magna flow exhaust
    I just got my first tacoma 2004 3.4L trd when I went into 4 low with rear locking dif the abs light comes on is this normal or not
  2. Nov 25, 2013 at 7:48 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    on the 2nd gens its normal, disables the abs
  3. Dec 1, 2013 at 11:01 AM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Yes it's normal for the abs light to be on in 4lo with the diff locked, when your rear diff is locked it disables your abs and the light comes on in the dash,hope this helps.
  4. Dec 1, 2013 at 12:02 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    be glad. ABS is bad news on the trail
  5. Dec 1, 2013 at 4:03 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Normal... think about it... if the rear tires 'locked' together, how can ABS pulse the rotation on one rear tire and not the other?
